Any recommendations on a jig to hold rear end #2585060
11/30/18 09:12 AM
11/30/18 09:12 AM
ME
79machocharger Offline OP
ME
Looking to make a jig to hold the rear end for tear down, move, paint and installation. I’ve seen a few that like but just wondering if any of you want to share what you have made. I’m thinking of making one like the one pictured.
Re: Any recommendations on a jig to hold rear end [Re: 79machocharger] #2585063
11/30/18 09:32 AM
11/30/18 09:32 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
You might want to add something that can prevent the axle from rotating if needed e.g. when fitting the pumpkin
Re: Any recommendations on a jig to hold rear end [Re: 79machocharger] #2585069
11/30/18 10:22 AM
11/30/18 10:22 AM
ME
ME
That’s actually what I don’t understand if you look at the one they on grave yard cars they don’t have any thing preventing it from spinning. It looks like it works really slick though when hooking up to car on lift.
Re: Any recommendations on a jig to hold rear end [Re: 79machocharger] #2585084
11/30/18 11:02 AM
11/30/18 11:02 AM
AndyF Online content
AndyF  Online Content
I made a bracket that mounts to my transmission jack. This way I can easily move the rear end around the shop and R&R it from the car.
Re: Any recommendations on a jig to hold rear end [Re: AndyF] #2585086
11/30/18 11:07 AM
11/30/18 11:07 AM
ME
ME
That’s pretty slick!
Re: Any recommendations on a jig to hold rear end [Re: 79machocharger] #2585135
11/30/18 12:47 PM
11/30/18 12:47 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That's the unit they store the finished product on - along with the engine, etc. The unit they rebuild on is likely better suited to the job.
Re: Any recommendations on a jig to hold rear end [Re: Stanton] #2585137
11/30/18 12:51 PM
11/30/18 12:51 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
And more than likely once the springs are installed it is probably more stable and less likely to rotate... twocents
...FAFO...
Re: Any recommendations on a jig to hold rear end [Re: 79machocharger] #2585227
11/30/18 03:55 PM
11/30/18 03:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I fabbed up one from some wood I had laying about while I was mocking up my discs.
Nice height for me to work on it standing up next to my bench. Was a grunt picking it up and putting it on the rack, next time I might get my engine hoist out to do it, but probably not.
Don't be the exception.
Re: Any recommendations on a jig to hold rear end [Re: Supercuda] #2585282
11/30/18 06:19 PM
11/30/18 06:19 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Cheap and dirty.....
Re: Any recommendations on a jig to hold rear end [Re: 79machocharger] #2585305
11/30/18 07:02 PM
11/30/18 07:02 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
I frequent another forum and one of the members there (zmotorsports) is extremely talented. Here is a link to his axle stand fabrication.
Start reading from Post 413 to 436
https://www.garagejournal.com/forum/showthread.php?p=6878882&highlight=axle#post6878882
Re: Any recommendations on a jig to hold rear end [Re: larry4406] #2585584
12/01/18 11:37 AM
12/01/18 11:37 AM
ME
ME
Thanks for the link that’s what I was looking for!
Starting making it this morning
Re: Any recommendations on a jig to hold rear end [Re: 79machocharger] #2585620
12/01/18 01:08 PM
12/01/18 01:08 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Your welcome. Zmotorsports is a very talented guy if you happen to read his whole thread and some of his other posts on that forum.
Take pics of your build and show it off when done.
Re: Any recommendations on a jig to hold rear end [Re: 79machocharger] #2585626
12/01/18 01:24 PM
12/01/18 01:24 PM
BDW Online content
BDW  Online Content
The wood stand looks like the perfect solution for a hobbyist.
Re: Any recommendations on a jig to hold rear end [Re: 79machocharger] #2585861
12/01/18 10:30 PM
12/01/18 10:30 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
that first picture you show it has a gray rubber pad that may limit the tendency to spin----if you had a vice grip with a grip chain it could grip around the axle and the metal plate with the gray pad....thats what i did on my axle appliance.
Re: Any recommendations on a jig to hold rear end [Re: 79machocharger] #2586215
12/02/18 05:44 PM
12/02/18 05:44 PM
Maryland
MoparMike1974 Offline
Maryland
I used saw horses. Set the spring pad on the sawhorse and c clamp it in place .Works just fine and didnt have to build anything. I dont see a need for a special jig unless you plan on doing rear's all the time.
Re: Any recommendations on a jig to hold rear end [Re: 79machocharger] #2586483
12/03/18 08:36 AM
12/03/18 08:36 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Some say I'm cheap and lazy...
I'd rather call it quick and efficient myself... wink
Re: Any recommendations on a jig to hold rear end [Re: BigBlockMopar] #2587164
12/04/18 07:53 PM
12/04/18 07:53 PM
ME
ME
Well got it mostly done, now I’m just going sand blast it and paint it. When I go to bolt in into the car I’ll grab it in closer to the member so I can install it with springs bolted on it. I’m making a round clamp bracket that bolts into treaded studs that are already on my arms.
Re: Any recommendations on a jig to hold rear end [Re: 79machocharger] #2587497
12/05/18 02:05 PM
12/05/18 02:05 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Cheapest way to work on one that I've found was a 5 gallon bucket with the nose of the housing down in the bucket.
Getting it up there, out, and installed are a different story, but the bucket held it off the ground.
Re: Any recommendations on a jig to hold rear end [Re: 79machocharger] #2587714
12/05/18 07:54 PM
12/05/18 07:54 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
I like how you used the perches to secure it!
Re: Any recommendations on a jig to hold rear end [Re: larry4406] #2587951
12/06/18 06:48 AM
12/06/18 06:48 AM
ME
ME
It worked better then I could have imagined.
