6pk ? #2585096
11/30/18 11:33 AM
11/30/18 11:33 AM
arizona, usa
lokalik Offline OP
lokalik  Offline OP
arizona, usa
6pk big block, do the outboard carbs open at the same time or is the opening staggered. Thanks
Re: 6pk ? [Re: lokalik] #2585102
11/30/18 11:49 AM
11/30/18 11:49 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Same time.
Re: 6pk ? [Re: lokalik] #2585229
11/30/18 03:59 PM
11/30/18 03:59 PM
With the stock vacumm carbs. they should both open and close at the same time, if the vacumm pod and linkage are set up correctly and operating correctly up
If not working or set up properly they can cause you a lot of grief shruggy
I like six packs up
Re: 6pk ? [Re: lokalik] #2585269
11/30/18 05:08 PM
11/30/18 05:08 PM
A727Tflite Offline
A727Tflite  Offline
A) Do the outboards open at the same time as each other?
B) Do the outboards open at the same time as the center
Which are you asking?
A) if using the standard linkage - yes.
B no, but if set up properly its aweful close.
Re: 6pk ? [Re: lokalik] #2585507
12/01/18 01:43 AM
12/01/18 01:43 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It only takes a very small amount of vacuum to open the end carburetors, it ANYTHING is hanging up it can easily stop one or both from opening. If one of them does not open first verify that it is getting vacuum, then check for mechanical hangups (butterflies can hang on gaskets, carb can be misaligned over intake holes, the shaft can be binding, etc.).
.02
Re: 6pk ? [Re: lokalik] #2585512
12/01/18 01:51 AM
12/01/18 01:51 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
hehe is on for you !
i had a outboard carb with a ac pod diaphram that did not have the hole for the vacuum to pass through to open the pod !
no they do not open by just reving the engine , it needs to be under load !
