Re: Aftermarket power window kit
[Re: varunner]
#2584635
11/29/18 12:49 PM
11/29/18 12:49 PM
Guitar Jones
Please note this kit is designed to replace your factory window regulator and offer quick smooth performance. This kit is also designed to work on Dodge Challenger 1970 - 1974’s that have modified doors and channels. Modified how exactly and that door glass isn't flat is it?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: varunner]
#2584650
11/29/18 01:10 PM
11/29/18 01:10 PM
DaytonaTurbo
Manitoba, Canada
I used these a few times: https://www.ebay.com/itm/Metra-Install-B...75.c10#viTabs_0They work with your original crank window regulators and are super easy to install. Just be sure to find ones that are made by spal, another member commented the off-brand ones don't have enough jam to work the windows effectively. I used the spal ones and they worked fine on every vehicle I've done them in.
[Re: varunner]
#2628495
03/03/19 11:57 PM
03/03/19 11:57 PM
70duster340
[Re: varunner]
#2628694
03/04/19 02:52 PM
03/04/19 02:52 PM
70duster340
[Re: 70duster340]
#2628903
03/04/19 11:16 PM
03/04/19 11:16 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Come on man... the pictures posted already answer your questions. But so I don't look too much of a jerk.... 1) Yes the window cranks need to be removed 2) There is a black cap that goes over the hole, you can see it in the link for the kit, posted above... It does look a little cheesy, but it's a universal kit. GoodBye
