Re: Oil pan question
[Re: RoadRunnerJD]
#2583103
11/26/18 01:59 AM
11/26/18 01:59 AM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
Great summary. Now that you showed the photos, I remember using the 1970 6 quart Hemi/440-6 pan which came on 1970 B and E-Body cars on my 69 A12 to get a little extra capacity but still look stock. Thanks for going to the trouble to show all the photos.
[Re: RoadRunnerJD]
#2583116
11/26/18 04:07 AM
11/26/18 04:07 AM
Posts: 2,855 Pattison Texas
CSK
Pattison Texas
most c body pans run on a 68-70 b body will have the drag link rubbing the pan, the c body pan is deeper [thicker] in that area of the pan.
[Re: NANKET]
#2583122
11/26/18 04:31 AM
11/26/18 04:31 AM
Posts: 43,129 Bend,OR USA
Cab_Burge
Whaaaat? The above statement is false. I have run 187 pans in b-bodies and they don't hit the drag link, ever. And a 66-70 b-body engine to K frame and suspension is the same dimensions.
Yes a 187 pan is thicker than a 402 pan. But a 66-69 hemi pan is thicker than a 402 also. They don't rub the drag link. They fit the car and dont hit anything. I've seen the 187 pan rub on 1965 B bodies, also on the 1966 and up B bodies Me thinks it depends on how old the motor and trans mounts are and the individual cars
[Re: NANKET]
#2583123
11/26/18 04:31 AM
11/26/18 04:31 AM
CSK
Pattison Texas
Yes a 187 pan is thicker than a 402 pan. But a 66-69 hemi pan is thicker than a 402 also. They don't rub the drag link. They fit the car and dont hit anything. you can say what you want to, I have seen it with my own eyes, more than once, & on different cars. but thats ok, ask Hemi68charger about his Daytona with a c body pan when it had a 440 in it,my own 68 Charger had the same problem.
[Re: RoadRunnerJD]
#2583351
11/26/18 07:21 PM
11/26/18 07:21 PM
CSK
Pattison Texas
Thanks all for the input. I am not worried about it in a B-Body. I was asking if it’s OK to use it in an E-Body. Looks like it will be fine. On a side note, I really like the baffles in it. I apologize for the Hijack of your Thread!!!
[Re: CSK]
#2583563
11/27/18 03:22 AM
11/27/18 03:22 AM
RoadRunnerJD
Warrenton, VA
Thanks all for the input. I am not worried about it in a B-Body. I was asking if it’s OK to use it in an E-Body. Looks like it will be fine. On a side note, I really like the baffles in it. I apologize for the Hijack of your Thread!!! I thought it was interesting...
