Oil pan question #2582886
11/25/18 05:42 PM
11/25/18 05:42 PM
Warrenton, VA
RoadRunnerJD Offline OP
Warrenton, VA
Will a 187 big block pan work with a big block in an E-Body car? It’s originally a 67-70 C-Body big block pan
Re: Oil pan question [Re: RoadRunnerJD] #2582889
11/25/18 05:49 PM
11/25/18 05:49 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
yes, with the correct "187" pick up
Re: Oil pan question [Re: RoadRunnerJD] #2582966
11/25/18 08:08 PM
11/25/18 08:08 PM
Warrenton, VA
Warrenton, VA
Thanks. I had it under my bench for about 25 yrs...wonder if I have one for it? scope
Re: Oil pan question [Re: RoadRunnerJD] #2582990
11/25/18 08:45 PM
11/25/18 08:45 PM
I Googled it & found a pic of it
Re: Oil pan question [Re: RoadRunnerJD] #2583014
11/25/18 09:44 PM
11/25/18 09:44 PM
Warrenton, VA
Warrenton, VA
I see a lot of references that the 187 pan works in an A-Body but no mention of it in an E-Body?
Re: Oil pan question [Re: RoadRunnerJD] #2583099
11/26/18 01:49 AM
11/26/18 01:49 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
e-bodies used the "402" pan for 383s & the "HEMI" pan for 440/440+6/HEMI
I think any big-block pan will fit in a '66-'70 B or '70-'74 E-body
the idler arm clearance of the C-body pan is necessary for the same in a big block A-body - it has been talked about due to the rarity of the "893" factory big-block A-body pan (now reproduced)
Re: Oil pan question [Re: RoadRunnerJD] #2583103
11/26/18 01:59 AM
11/26/18 01:59 AM
Warrenton, VA
Warrenton, VA
Great summary. Now that you showed the photos, I remember using the 1970 6 quart Hemi/440-6 pan which came on 1970 B and E-Body cars on my 69 A12 to get a little extra capacity but still look stock. Thanks for going to the trouble to show all the photos.
Re: Oil pan question [Re: RoadRunnerJD] #2583116
11/26/18 04:07 AM
11/26/18 04:07 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
most c body pans run on a 68-70 b body will have the drag link rubbing the pan, the c body pan is deeper [thicker] in that area of the pan.
Re: Oil pan question [Re: RoadRunnerJD] #2583120
11/26/18 04:19 AM
11/26/18 04:19 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Whaaaat? The above statement is false. I have run 187 pans in b-bodies and they don't hit the drag link, ever. And a 66-70 b-body engine to K frame and suspension is the same dimensions.
Yes a 187 pan is thicker than a 402 pan. But a 66-69 hemi pan is thicker than a 402 also. They don't rub the drag link. They fit the car and dont hit anything.
Re: Oil pan question [Re: NANKET] #2583122
11/26/18 04:31 AM
11/26/18 04:31 AM
I've seen the 187 pan rub on 1965 B bodies, also on the 1966 and up B bodies shruggy
Me thinks it depends on how old the motor and trans mounts are and the individual cars shruggy
Re: Oil pan question [Re: NANKET] #2583123
11/26/18 04:31 AM
11/26/18 04:31 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
you can say what you want to, I have seen it with my own eyes, more than once, & on different cars. but thats ok, ask Hemi68charger about his Daytona with a c body pan when it had a 440 in it,my own 68 Charger had the same problem.
Re: Oil pan question [Re: RoadRunnerJD] #2583165
11/26/18 12:13 PM
11/26/18 12:13 PM
Warrenton, VA
Warrenton, VA
Thanks all for the input. I am not worried about it in a B-Body. I was asking if it’s OK to use it in an E-Body. Looks like it will be fine. On a side note, I really like the baffles in it.
Re: Oil pan question [Re: RoadRunnerJD] #2583351
11/26/18 07:21 PM
11/26/18 07:21 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I apologize for the Hijack of your Thread!!!
Re: Oil pan question [Re: RoadRunnerJD] #2583375
11/26/18 08:12 PM
11/26/18 08:12 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I've had C body pans rub the center links in both B and E bodies.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Oil pan question [Re: 6bblgt] #2583399
11/26/18 09:07 PM
11/26/18 09:07 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Heisting my pictures I see !! tsk grin
Re: Oil pan question [Re: CSK] #2583563
11/27/18 03:22 AM
11/27/18 03:22 AM
Warrenton, VA
Warrenton, VA
I thought it was interesting... up
Re: Oil pan question [Re: RoadRunnerJD] #2583931
11/27/18 11:18 PM
11/27/18 11:18 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Here is what it looks like 67 b-Body 426 with hemi pan. Measurement from bottom of block to the drag link 2 5/8" you can't get a pencil between the pan and drag link. If the idler arm is good the the drag link does not move up and down just side to side.
A 187 pan is 2 7/16" in this area.
So I don't know what was wrong with your b-body that a 187 pan that hit the drag link, but there was a problem someplace. I had one and drove it for years.
