Fender-to-front panel gasket??? #2582410
11/24/18 03:22 PM
11/24/18 03:22 PM
PORT ALBERNI , BC., CANADA
superwrench Offline OP
On my old '54 C1B pickup, is there anything that goes between the front headlamp /grille panel and the front mounting flange of the fenders?? The parts book shows some sort of "anti-squeak"
material, but nothing available anymore. Should I just use a narrow bead of butyl?? Or what have others been using....?
Re: Fender-to-front panel gasket??? [Re: superwrench] #2582700
11/25/18 03:33 AM
11/25/18 03:33 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The first time I assembled my 54 Dodge pickup, I used a calk rope flattened out. That didn't last a year. The next time, I just bolted the stuff together, and that was the way it was when it left me 7 years later. I really didn't hear many squeaks, but the truck had a rumble that probably muffled me from hearing any squeaks.
Butyl might work OK, at least it won't squish out very fast. Gene
Re: Fender-to-front panel gasket??? [Re: poorboy] #2582709
11/25/18 04:20 AM
11/25/18 04:20 AM
Thanks Gene....I was thinking on just bolting them together too....Can't really hurt I guess.
Re: Fender-to-front panel gasket??? [Re: superwrench] #2582718
11/25/18 08:44 AM
11/25/18 08:44 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Probably used welting material originally. You might be able to find it in bulk from one of the weather strip suppliers
Old bicycle inner tube could be trimmed to fit
Angry white pureblood male
Re: Fender-to-front panel gasket??? [Re: ruderunner] #2582768
11/25/18 12:57 PM
11/25/18 12:57 PM
mn
flyman Offline
flyman  Offline
mn
I used plumbers caulking tape on my 57. Worked great.
Re: Fender-to-front panel gasket??? [Re: superwrench] #2583915
11/27/18 10:44 PM
11/27/18 10:44 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
some of those old trucks had that welting material with a round bead that would show between the fender and body-----buy some turn the bead in or trim it off.....
