Dimension needed for bumper install #2581941
11/23/18 03:20 PM
11/23/18 03:20 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
If I could get someone with a 70-71 challenger to do a quick pull tape measurement, I'd appreciate it. Just pulled my new AMD front bumper out of the box and tried to install it. I have the correct brackets on the car. For the 4 bolts that attach the brackets to the bumper, the outer 2 line up fine, the inner 2 are both off 2". The distance between the inner 2 bolts on my brackets is 19 5/8". I'm pretty confident the bumper is bad, but if someone can just measure between those bolts as installed on their bumper, that would work. thanks
Re: Dimension needed for bumper install [Re: varunner] #2581947
11/23/18 03:44 PM
11/23/18 03:44 PM
St. Louis, Mo
3
318 Stroker Online content
318 Stroker  Online Content
St. Louis, Mo
I have a 73 Challenger, but when I restored the car, I installed the 70-71 bumper brackets so that I could suck the bumpers in, and I got the correct bumper for the brackets. I just measured mine, and the distance between bolt hole centers is 23 1/4". Are you sure you have the correct brackets? Yours being 19 5/8", that would roughly account for your difference of 2" per side. Could yours be 73-74 brackets?
Re: Dimension needed for bumper install [Re: varunner] #2581952
11/23/18 03:53 PM
11/23/18 03:53 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I did a web search and looked correct. I have a parts manual, I'll check. here are my numbers off the bracket.
2962330
2962335
Re: Dimension needed for bumper install [Re: varunner] #2581967
11/23/18 04:32 PM
11/23/18 04:32 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
My left side part numbers are in the parts catalog, but not the right side. weird. All 4 of the numbers are in close sequence, so it seems like the correct pn for the car. your dimension of 23 1/4 pretty much matches up with my AMD bumper, so I guess it's a bracket issue, they sure don't look bent or modified...........
Re: Dimension needed for bumper install [Re: varunner] #2581977
11/23/18 04:52 PM
11/23/18 04:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
From my parts manual
bumper -
1970 early 71 - 2962275
feb 71 to jun 71 - 3595062
after jun 71 - 3595032
Not sure what is different exactly, I know the jacking point changed, but not sure if that is all that changed,
you bracket numbers match my parts manual info.
Don't be the exception.
Re: Dimension needed for bumper install [Re: varunner] #2581982
11/23/18 05:04 PM
11/23/18 05:04 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
thanks for checking. here's a picture of when I first got the car. missing inner bolts, the bumper didn't fit then either !
Re: Dimension needed for bumper install [Re: varunner] #2582022
11/23/18 06:05 PM
11/23/18 06:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, I assume the bumper in the before pic is not the AMD part. If not and it didn't fit, why would you think it's the new AMD bumper that is the issue?
Re: Dimension needed for bumper install [Re: varunner] #2582035
11/23/18 06:23 PM
11/23/18 06:23 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
pic is 14 years old, I didn't notice it was missing the bolts until after the post
