Alternators #2579229
11/16/18 05:02 PM
11/16/18 05:02 PM
Brodheadsville Pa.
franko Offline OP
franko  Offline OP
Brodheadsville Pa.
I have a stock alternator on my 73 Challenger and I would like to change it to a larger 100 amp type alternator .My question other than it fitting, is the field wiring the same?
Re: Alternators [Re: franko] #2579247
11/16/18 05:34 PM
11/16/18 05:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Depends on which 100A alternator you are using. If it's a Chrysler one then yes.
Don't be the exception.
Re: Alternators [Re: franko] #2579248
11/16/18 05:35 PM
11/16/18 05:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Depends on the alternator you choose, some high-output alternators wire just like the original single and dual field terminal units.
http://www.qualitypowerauto.com/item_557/Chrysler-Mount-Mega-Amp-Alternator.htm
Re: Alternators [Re: John_Kunkel] #2579281
11/16/18 07:25 PM
11/16/18 07:25 PM
Brodheadsville Pa.
franko Offline OP
franko  Offline OP
Brodheadsville Pa.
It seems to be a Chrysler part,the two field connectors are stacked one on top of the other.i will post pics when I figure out how to do that it’s been a while since I’ve been here on the side
E71B1D14-D094-4521-A59A-B34A02D14BD9.jpegB8DF1771-E25F-449C-B613-09C456AD1759.jpegB8622F58-82B5-4BC0-93F4-431897603BE9.jpeg72E6D8BF-99A5-4766-9FD3-DA8A5D3CDD68.jpeg
Re: Alternators [Re: franko] #2579287
11/16/18 07:38 PM
11/16/18 07:38 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Alternators [Re: franko] #2579289
11/16/18 07:42 PM
11/16/18 07:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That's a Chrysler 117A unit, works the same.
Re: Alternators [Re: Supercuda] #2579298
11/16/18 08:30 PM
11/16/18 08:30 PM
agreed, read the allpar sheet, you want all your voltage drops minimal (clean all terminals/connections including ground paths & grab your meter). On a side note there are 2 pulley sizes on our alts that I have seen (I forget the measurements) and you might have the larger one & a swap to a smaller one would help (not sure how much) tho it would involve splitting the halves & haveing a shop R&R the old new pulleys. EDIT the one in the pic is that a Leece Neville? I have one of em with the special bracketry for it. MORE EDIT with some easy math you could figure the additional alt speed you would gain from the pulley swap. Then what general RPM "range" are you in now where there is inadequate charging/will the pulley swap get the alt pulley RPM above that & into an "adequate" charging range" for a sufficient % of your driveing time to take care of the issue (& checking/cleaning terminals as needed) or if a better alt is needed. Relays get very good reviews (for heater/headlights/AC). 2&3/4" and 3&3/4" vaguely comes to mind on pulley dia's but I ain't sure.
Re: Alternators [Re: franko] #2579315
11/16/18 09:09 PM
11/16/18 09:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The alternator pictured is a Leece-Neville, common on cop cars of the sixties/seventies; takes a special regulator.
Re: Alternators [Re: John_Kunkel] #2579319
11/16/18 09:18 PM
11/16/18 09:18 PM
John you ARE the man! what reg does it take & where is the other field terminal?
Re: Alternators [Re: franko] #2579327
11/16/18 09:37 PM
11/16/18 09:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Stacked one atop the other
Re: Alternators [Re: Supercuda] #2579364
11/16/18 11:18 PM
11/16/18 11:18 PM
Brodheadsville Pa.
franko Offline OP
franko  Offline OP
Brodheadsville Pa.
Thanks everyone I am left with more information and still lost?
Re: Alternators [Re: franko] #2579366
11/16/18 11:22 PM
11/16/18 11:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I ran one of those for a couple years on my 87 Diplomat, retrofitted it, using the normal regulator, worked just fine.
Re: Alternators [Re: Supercuda] #2579376
11/16/18 11:35 PM
11/16/18 11:35 PM
Yes I see it now! & that is good to hear a "regular" reg will suffice. Thank you!
Re: Alternators [Re: franko] #2579379
11/16/18 11:38 PM
11/16/18 11:38 PM
Keep posting with any & all Q's (no matter how mundane) as that is what we (& Moparts) are here for.
Re: Alternators [Re: franko] #2579557
11/17/18 02:11 PM
11/17/18 02:11 PM
moparx Offline
moparx  Offline
those bigun's take a special bracket. if you are putting one on a big block, i have a bracket setup for a 440 i'm never gonna use. PM me if interested.
beer
Re: Alternators [Re: moparx] #2579633
11/17/18 07:11 PM
11/17/18 07:11 PM
IN
ahy Offline
ahy  Offline
IN
I run that alternator on a B big block. I started with a 75 amp square back but not enough output for EFI and EFI fuel pump. I had the big alternator and special bracket from my core engine.
On the plus side, it has plenty of idle output. Works great in that respect. Downside is weight... very heavy. Last I checked reman replacements are available for service... though a reman on a 40 YO core may be iffy.
It works fine on a standard replacement regulator.
Re: Alternators [Re: franko] #2579635
11/17/18 07:21 PM
11/17/18 07:21 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
If U are going to run a high amperage alternator, U should consider upgrading the wiring harness...
Just my $0.02... wink
Re: Alternators [Re: franko] #2579663
11/17/18 09:10 PM
11/17/18 09:10 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Or more precisely, if the equipment is being added where the loads require that alternator, then the wiring should be matched to the new loads.
ahy's setup is such an example.
Re: Alternators [Re: Mattax] #2579675
11/17/18 09:51 PM
11/17/18 09:51 PM
IN
ahy Offline
ahy  Offline
IN
Agree with the comments on upgrading wiring with a big alternator. I run a 6 gauge charge wire from alternator to the battery main cable. No charge current passing through the bulkhead connector. The ammeter in the Rally cluster was stealth converted to a voltmeter.
Re: Alternators [Re: franko] #2579747
11/18/18 02:42 AM
11/18/18 02:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Most Mopars through the 60's and 70's used either the mechanical reg with a single field wire and a grounded brush or the electronic 2 pin reg and the dual field grounded at the reg. But some Imperial's used this system here on the link which is not seen alot as even working 24 years at a Dodge dealer I rarely saw this. This is the 3 pin voltage reg and this setup has a 12 volts fed to one field brush all the time from the rectifier inside the alt. It still controls the ground at the reg but the field wire at the reg is hot even with the ign key off. That's why this uses the ign 12 volt to power up the reg and has a battery volt feed to the reg to check battery volts where the 2 pin electronic reg uses 12 volts through the key on ign to check battery volts. If by chance anyone ever uses this style alt it has to use the right 3 pin reg. Ron
http://www.imperialclub.com/Repair/Lit/Master/256/back.htm
