Re: Alternators
[Re: franko]
#2579247
11/16/18 05:34 PM
11/16/18 05:34 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Depends on which 100A alternator you are using. If it's a Chrysler one then yes.
Re: Alternators
[Re: franko]
#2579287
11/16/18 07:38 PM
11/16/18 07:38 PM
Posts: 13,616 md
mopars4ever
md
Re: Alternators
[Re: franko]
#2579289
11/16/18 07:42 PM
11/16/18 07:42 PM
Supercuda
About to go away
About to go away
up yours
That's a Chrysler 117A unit, works the same.
Re: Alternators
[Re: Supercuda]
#2579298
11/16/18 08:30 PM
11/16/18 08:30 PM
RapidRobert
agreed, read the allpar sheet, you want all your voltage drops minimal (clean all terminals/connections including ground paths & grab your meter). On a side note there are 2 pulley sizes on our alts that I have seen (I forget the measurements) and you might have the larger one & a swap to a smaller one would help (not sure how much) tho it would involve splitting the halves & haveing a shop R&R the old new pulleys. EDIT the one in the pic is that a Leece Neville? I have one of em with the special bracketry for it. MORE EDIT with some easy math you could figure the additional alt speed you would gain from the pulley swap. Then what general RPM "range" are you in now where there is inadequate charging/will the pulley swap get the alt pulley RPM above that & into an "adequate" charging range" for a sufficient % of your driveing time to take care of the issue (& checking/cleaning terminals as needed) or if a better alt is needed. Relays get very good reviews (for heater/headlights/AC). 2&3/4" and 3&3/4" vaguely comes to mind on pulley dia's but I ain't sure.
Re: Alternators
[Re: franko]
#2579315
11/16/18 09:09 PM
11/16/18 09:09 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The alternator pictured is a Leece-Neville, common on cop cars of the sixties/seventies; takes a special regulator.
Re: Alternators
[Re: John_Kunkel]
#2579319
11/16/18 09:18 PM
11/16/18 09:18 PM
RapidRobert
John you ARE the man! what reg does it take & where is the other field terminal?
Re: Alternators
[Re: franko]
#2579327
11/16/18 09:37 PM
11/16/18 09:37 PM
Supercuda
About to go away
About to go away
up yours
Stacked one atop the other
Re: Alternators
[Re: franko]
#2579366
11/16/18 11:22 PM
11/16/18 11:22 PM
Supercuda
About to go away
About to go away
up yours
I ran one of those for a couple years on my 87 Diplomat, retrofitted it, using the normal regulator, worked just fine.
Re: Alternators
[Re: Supercuda]
#2579376
11/16/18 11:35 PM
11/16/18 11:35 PM
RapidRobert
Stacked one atop the other Yes I see it now! & that is good to hear a "regular" reg will suffice. Thank you!
Re: Alternators
[Re: franko]
#2579379
11/16/18 11:38 PM
11/16/18 11:38 PM
RapidRobert
Thanks everyone I am left with more information and still lost? Keep posting with any & all Q's (no matter how mundane) as that is what we (& Moparts) are here for.
