Re: Hurst V Gate shifter fitment
[Re: madscientist]
#2578966
11/15/18 11:10 PM
11/15/18 11:10 PM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
If you are referring to the red t-handle that pulls up to lock out reverse we are on the same page. They don't make those anymore as far as I know.
[Re: Jeremiah]
#2578969
11/15/18 11:16 PM
11/15/18 11:16 PM
Posts: 4,457 Washington
madscientist
Washington
If you are referring to the red t-handle that pulls up to lock out reverse we are on the same page. They don't make those anymore as far as I know. Correct. That's a Super Shifter III. I did see some remans on eBay but they want pretty good money for them.
[Re: MadMopars]
#2578990
11/16/18 12:38 AM
11/16/18 12:38 AM
Posts: 8,928 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The Super Shifter does not have a reverse lockout. The Super Shifter does have a reverse lockout. ??? Make up your mind !!
[Re: Stanton]
#2578995
11/16/18 01:01 AM
11/16/18 01:01 AM
Posts: 10,563 Rittman Ohio
fourgearsavoy
Rittman Ohio
The Hurst "Ram-4" looks like it would work but I tried to race one with a slicked up Hemi box and I prefer the Super Shifter III or a Long V-gate . My favorite was Long V-gate and Heim joint linkage. I purchased my tubing from Liberty Gears and the heims from Long. I also used a Long V-gate on my Richmond with Face-plate gears from Liberty and it was so much fun to do full throttle power shifts never missing a gear. Spend the money on a Long shifter for a V-gate or look for a NASCAR Hurst shifter or "good used" Super Shifter III if you want an "H" pattern deal Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Stanton]
#2579013
11/16/18 01:55 AM
11/16/18 01:55 AM
madscientist
Washington
The Super Shifter does not have a reverse lockout. The Super Shifter does have a reverse lockout. ??? Make up your mind !! The junk [censored] iPad decided to remove the III I typed. I've posted several times how it was, but I'll do it again for the crowd that wasn't there to live through the era or have reading issues. The SUPER SHIFTER does NOT have a lock out lever, and AFAIK never did. The SUPER SHIFTER III does have a reverse lock out lever, and AFAIK always did. It's that simple. There are guys who swear on their mothers grave they had a SUPER SHIFTER III without a reverse lockout but I've never seen one. Ever.
[Re: MadMopars]
#2579034
11/16/18 04:02 AM
11/16/18 04:02 AM
Posts: 9 OR
The real scienti
OR
Also yeah I cut a little chunk out of that hump and just saved it and weld it back in and now I'll just cut the line back out again no big deal it's just a little piece. At least for my 73 a body.
[Re: MadMopars]
#2579041
11/16/18 04:41 AM
11/16/18 04:41 AM
Posts: 5,124 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
My Challenger tunnel was cut a long time ago and I have had most shifters in the car but the one I prefer is the Mr. Gasket Vertical gate shifter. I use the B Body V Gate shifter in my E Body. I prefer that location over all other shifters.
1971 HEMI E BODY REGISTRY
[Re: The real scienti]
#2579044
11/16/18 05:02 AM
11/16/18 05:02 AM
madscientist
Washington
^^^^well instead of listening to somebody who doesn't even have a car^^^^ I can tell you I absolutely love my vertigate. I never had a second to third shift any faster than slamming straightforward! I took it out thinking I just wanted the ball shifter for Comfort but now I miss that 3rd gear bang.. I was using a V-Gate shifter while you were still sucking your thumb. Don't you have a snowmobile to waste time with?
#2579092
11/16/18 12:16 PM
11/16/18 12:16 PM
madscientist
Washington
In what? You got to have a car to have a vertigate don't you? If you are THAT lonely, you can always call me. Yes I have a car. It will never get a V-Gate because I'm not going to put a big hole in the tunnel. Still driving my car mostly every day. The weather is beautiful, except it's in the low 20's at night. Practice up. You'll need it.
[Re: MadMopars]
#2579108
11/16/18 12:45 PM
11/16/18 12:45 PM
Posts: 9 OR
The real scienti
OR
Never happened...
[Re: MadMopars]
#2579109
11/16/18 12:49 PM
11/16/18 12:49 PM
Posts: 9 OR
The real scienti
OR
All clear
