Page 1 of 3 1 2 3
Anti-Robocall spoofing “shaken/stir” proposal #2575751
11/08/18 09:43 AM
11/08/18 09:43 AM
USA
3
360view Offline OP
Moparts resident spammer
360view  Offline OP
3
USA
https://www.pcmag.com/news/364829/fcc-to-carriers-adopt-anti-robocall-system-by-2019-or-else
Sample quote
The authentication system Pai wants is called the "SHAKEN/STIR framework," an industry-developed standard. With the framework in place, "calls traveling through interconnected phone networks would be 'signed' as legitimate by originating carriers and validated by other carriers before reaching consumers," according to the FCC. As result, consumers would be able see on their phones via the caller ID whether an incoming call was suspicious or not.
Snip
The commission notes that it receives more consumer complaints about unwanted calls than any other subject. YouMail, a company that tracks the problem, estimates that over 4.2 billion robocalls were received across the US in August alone.
End quote
Now totally out of control, it certainly ought to be possible to iID spoofing of numbers and blocking overseas criminal call centers.
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: 360view] #2575871
11/08/18 02:13 PM
11/08/18 02:13 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I like it. Right now if I don't know the number or if its blocked, private etc I don't answer. Then if there is no VM I simply block and report it as spam.
Ok
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: 360view] #2577305
11/11/18 11:24 PM
11/11/18 11:24 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
NOMOROBO
https://www.nomorobo.com
its free
works very well imo
phone rings only once if its a spam/scam/robo caller
you can add any number it misses which for us has been very few
check to see if your phone provider is connected
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: 360view] #2577317
11/11/18 11:47 PM
11/11/18 11:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The FCC is useless.
I finally got tired of the overly loud commercials and filed a complaint with the FCC. After filling out a bunch of detailed questions I eventually got a response from the FCC. It said, and I quote:
"Your complaint provides the Commission with valuable information that we use to spot trends and practices that warrant investigation and enforcement action. We do not resolve individual complaints about this issue and, there will be no status information to report on your complaint."
Useless.
Don't be the exception.
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: 360view] #2577354
11/12/18 12:53 AM
11/12/18 12:53 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'm in the service biz and must answer my phone. I am getting HAMMERED with robo and recorded calls to press 2 to be put on the "do not call" list.Seems like every time I press that #2 they give my number to 10 other robos.
When I have the time,I like to mess with them,student loans,solor panels,credit cards,pharmacy stuff and when I detect the pilipino or Paki accent I ask to speak to someone in the US! smoke
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: Supercuda] #2577374
11/12/18 01:35 AM
11/12/18 01:35 AM
Massachusetts
Faust Offline
Faust  Offline
Massachusetts
Originally Posted By Supercuda
The FCC is useless.
Useless.
"We do not resolve individual complaints about this issue" I have dealt with FCC, and a few other similar agencies. Their regulations create "rights" for you to sue, but they only get involved if there is a headline it. Great, you can sue a robocaller that you can't even trace (here they sometimes use expired phone numbers. If the number is local, I Google it. 40% of the time I find an obituary) So, who you gonna sue? What are you going to get?
I get at least 10 a day on my landline.
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: 360view] #2577375
11/12/18 01:38 AM
11/12/18 01:38 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
When they answer from the auto dialer pause I just scream into the phone or ask if they are hookers. Sometimes they don't know what a hooker is.
NS1AAR
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: 360view] #2577466
11/12/18 01:23 PM
11/12/18 01:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It is extremely easy to fix these issues.
For example, in my loud commercial complaint the FCC can mandate that all commercials carry a digital signature that identifies it as a commercial and can allow your TV to mute the volume, or cut it in half or whatever you choose from your settings options. If a commercial gets aired without that signature you can sue your local provider, they aired it.
As for robocallers, simple there too. Require the phone companies to only pass calls with verified accurate caller ID and make them legally responsible for it. As in you can sue the phone company for this not robocallers, they can sue the robocallers. After all they know, ultimately, where that call started. Robocallers would end withing 30 seconds of that legislation going into effect.
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: Supercuda] #2577559
11/12/18 05:50 PM
11/12/18 05:50 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I don't understand why this is so hard to correct.
1. How many calls do you make a day?
2. How many do you think a robo caller makes a day?
3. How many legit companies need to make as many calls as #2?
4. Why can't the phone providers just monitor use, and limit the number of daily calls, with out a vetting process?
Seems simple to me.
Am I correct most people get robo calls come from their own area code?
I'm changing my next phone's area code to 406 (Montana), if you live in Montana, I will not answer your phone, sorry. biggrin
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: nomore65BelvJim] #2577578
11/12/18 07:08 PM
11/12/18 07:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By nomore65BelvJim
NOMOROBO
its free
works very well imo
I've got that too and I love it. My current record is 9 blocked calls in one day. thumbs
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: 360view] #2577620
11/12/18 08:53 PM
11/12/18 08:53 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I block all non contacts on my cell phone and once a month or so go back through and delete them all. When it leaves a voicemail, that's what ticks me off. I swear before I blocked them, I'd get 10 calls a day.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: 360view] #2728946
01/01/20 12:51 PM
01/01/20 12:51 PM
USA
3
360view Offline OP
360view  Offline OP
3
USA
President Trump has signed a law increasing fines on spammy robocalls and requiring phone service providers to begin authenticating calls across networks.
The Telephone Robocall Abuse Criminal Enforcement and Deterrence Act (TRACED Act) was signed on Monday, after Congress approved the landmark bill earlier this month to give the federal government new abilities to go after illegal robocallers. Fines can now reach $10,000 per call. The law also requires major carriers such as AT&T, Verizon, and T-Mobile to use a new technology called STIR/SHAKEN to help customers know if they’re being targeted by a robocaller with a spoofed number.
“I applaud Congress for working in a bipartisan manner to combat illegal robocalls and malicious caller ID spoofing,” Federal Communications Commission chairman Ajit Pai said in a statement. Pai added he’s glad the agency “has a longer statute of limitations” to pursue scammers.
Carriers have already begun to deploy the STIR/SHAKEN technology in anticipation of the new law, though support is still limited. Eventually, companies like AT&T and Verizon should be able to verify calls between their networks, ensuring a call is coming from a real, authentic number.
Trump’s signing of the TRACED Act into law is just another step in the ongoing battle the FCC has taken to fight robocalls under Pai. The commissioner announced over the summer that the FCC would move to make it illegal to send spoofed calls or texts from overseas. Congress passed new rules in 2018 allowing the commission to do so.
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: 360view] #2728987
01/01/20 02:13 PM
01/01/20 02:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Reportedly, currently won't work on hard lines.
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: John_Kunkel] #2729030
01/01/20 03:50 PM
01/01/20 03:50 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Seriously? You were expecting "thank you sir, we will immediately focus all resources on your issue and give you hourly updates" ?!?!?
Some people really do believe the earth revolves around them !!!
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: Stanton] #2729046
01/01/20 04:14 PM
01/01/20 04:14 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Gee, I wonder how automotive recalls are generates by the government? People complaint about something and if enough do so the government focuses s resources on it. Ever see the government fine a company for it's behavior towards consumers? Who do you think keeps that money? They sure don't hand it to the people affected by the issue.
Why have a law with no enforcement?
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: Sniper] #2729056
01/01/20 04:33 PM
01/01/20 04:33 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
It's so effin out of control on both cell and land lines that if my cell doesn't verbally announce the call as one of my contacts I just ignore it. My home phone is rarely used, and mostly to make calls with more clarity.
Facts are stubborn things.
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: larrymopar360] #2729257
01/02/20 07:55 AM
01/02/20 07:55 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
My calls come in waves. Some weeks I don't have any. I have an exchange from a cell provider that went defunct 20 years ago. Not many people have it so I ignore these cloned numbers when they pop up.
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: redraptor] #2729297
01/02/20 11:05 AM
01/02/20 11:05 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
They will find a new way to irritate us I am sure.
68 Barracuda Formula S 340
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: Supercuda] #2729472
01/02/20 09:12 PM
01/02/20 09:12 PM
jersey
Spaceman Spiff Offline
jersey
i didn't know my 20 year old TV had that kind of capability.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Anti-Robocall spoofing “shaken/stir” proposal [Re: Spaceman Spiff] #2729478
01/02/20 09:29 PM
01/02/20 09:29 PM
nowhere
nowhere
Your 20 year old TV no longer receives over the air signals either.
Page 1 of 3 1 2 3
