Re: CalTracs setup - Chassis separation or limit it?
[Re: nss guy]
#2575533
11/07/18 09:06 PM
11/07/18 09:06 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
That looks Great to me !!!!!
[Re: BradH]
#2575599
11/07/18 11:28 PM
11/07/18 11:28 PM
Posts: 4,679 On the parachute mount
n20mstr
Short front segment compared to GM cars. Always going to hit the tire hard. You need a good shock to control it all...
Dont you have a post that you want a "cheap" shock ?
Smh..lmfao !
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2575641
11/08/18 12:14 AM
11/08/18 12:14 AM
BradH
Tony - Not sure what "smh" means, but I'll take a guess it means you think I'm an idjit. EDIT: I already have "cheap" shocks. What I asked in the other post is recommendations for a reasonable and -- yes, affordable -- upgrade from what I have now.
[Re: nss guy]
#2575659
11/08/18 12:45 AM
11/08/18 12:45 AM
BradH
Your times are very close to mine, so it's a good comparison. Are those CalTrac (Rancho) 9-way adjustables? Did you notice your slicks try to unload shortly after the hit? See if you can slo-mo starting about the :58 mark. At least that's what I think I'm seeing.
[Re: BradH]
#2575667
11/08/18 12:52 AM
11/08/18 12:52 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Your times are very close to mine, so it's a good comparison. Are those CalTrac (Rancho) 9-way adjustables? Did you notice your slicks try to unload shortly after the hit? See if you can slo-mo starting about the :58 mark. At least that's what I think I'm seeing. I saw the same thing
68 Barracuda Formula S 340
[Re: BradH]
#2575696
11/08/18 02:17 AM
11/08/18 02:17 AM
n20mstr
Tony - Not sure what "smh" means, but I'll take a guess it means you think I'm an idjit. EDIT: I already have "cheap" shocks. What I asked in the other post is recommendations for a reasonable and -- yes, affordable -- upgrade from what I have now. Not at all, just giving you a hard time.....lol If I thought someone was an idiot, I wouldn't reply My sons duster has cal tracks with their split mono. He's got Afco double adj in the rear. They have to be quite stiff to control the hit, and he's been 1.45 10.99 . Honestly I think he needs more shock at this point. Look at this way , it's cheaper in the long run to buy santuff a or big gun Afros once, than buying Viking ,strange, or reg afcos.
[Re: nss guy]
#2575937
11/08/18 04:00 PM
11/08/18 04:00 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I had my sliders where yours are.If you watch the slider it maxes out at the hit almost inloading the tire.I moved the slider so that it is 80/20. I want a go-pro for Christmas!!!!! Also,I went Viking with the stiffer valving for the rear.
[Re: nss guy]
#2576080
11/08/18 10:07 PM
11/08/18 10:07 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
The key is to keep the tire planted.. controlling the rate of separation is Paramount.. you don't want to drive the tire into the ground
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: BradH]
#2576219
11/09/18 03:58 AM
11/09/18 03:58 AM
Posts: 10,003 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Look at how rise in the rear of a drag car gets less and less the faster the car gets. As acceleration decreases in a slower car, controled seperation keeps the tire loaded enough for good traction. Once you get enough weight and g force planting those tires to get the front off the ground, you don't need any. It takes virtually no seperation and about eight inches of forward travel in my dart to get there. My carhas the power to keep the tires planted very early. A high 10 sec car not as much. Every car and situation will vary.
[Re: gregsdart]
#2576295
11/09/18 12:56 PM
11/09/18 12:56 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I agree with Greg, there are big differences between a 2800lb 8sec car that scales well and a nose heavy 3800lb 12 sec car.
"Just a Bracket car dressed up like a streetcar"
[Re: BradH]
#2576465
11/09/18 05:44 PM
11/09/18 05:44 PM
Just-a-dart
Glendora Ca.
Brad that comment was not pointed at you.
If I was buying shocks for your car I would buy probably buy double adjustable AFCOs.
[Re: BradH]
#2576472
11/09/18 05:52 PM
11/09/18 05:52 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
My best 60ft has been a 1.33. It is always in the low 1.30's and I am using Rancho 9 ways on the back. I am using home made caltracs with stock leaf springs and shackles. I am running Drag Radial tires.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
