Cruise control with 4spd #2573234
11/02/18 09:55 PM
11/02/18 09:55 PM
KY USA
mopargem Offline OP
mopargem  Offline OP
KY USA
A friend of mine was wondering if cruise control was offered on 70 Mopars with a 4 spd. We both don’t think so but not sure ??
Re: Cruise control with 4spd [Re: mopargem] #2573238
11/02/18 10:01 PM
11/02/18 10:01 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It was called 'Automatic' Speed Control for a reason.
Details at http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1970/70_Belevedere0005.jpg
You were both right.
Re: Cruise control with 4spd [Re: Alaskan_TA] #2573249
11/02/18 10:16 PM
11/02/18 10:16 PM
KY USA
mopargem Offline OP
mopargem  Offline OP
KY USA
Thx Barry for the quick answer!
Re: Cruise control with 4spd [Re: mopargem] #2573255
11/02/18 10:36 PM
11/02/18 10:36 PM
Florida STAYcation
MasterDeBaTeR ! Online penguin-006
The village idiot's idiot
MasterDeBaTeR !  Online Penguin-006
Florida STAYcation
Let me add a Q in here .... anyone know of a add on cruise kit that is currently available ?
Re: Cruise control with 4spd [Re: mopargem] #2573259
11/02/18 10:50 PM
11/02/18 10:50 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I checked a few months ago and you can still get an aftermarket Rosetta Cruise control. They also have an extra cost switch that will allow the cruise to be added to a manual trans car.
Many years ago, I added an aftermarket cruise to my 70 Road Runner that had a 4 speed. There was a bead chain and a switch that connected between the clutch pedal and the brake pedal that was under a load when both pedals were up, as soon as you stepped on either the clutch or the brake, the chain went slack and the cruise disconnected the same way it would if you stepped on the brake with an auto trans. When both pedals were back up, and you were in 4th, you hit resume and the cruse was back working. It really worked well. I believe the Rosetta Cruise is an updated copy of the same one I had on my RR. Gene
Re: Cruise control with 4spd [Re: mopargem] #2573270
11/02/18 11:27 PM
11/02/18 11:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I had cruise and a 4 speed in my 87 Diplomat, but I put the 4 speed in it.
Don't be the exception.
Re: Cruise control with 4spd [Re: mopargem] #2573291
11/03/18 12:26 AM
11/03/18 12:26 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Both of our '89 LeBaron GTC TII/5sp convertibles had cruise. There was a clutch switch as well as a brake switch. I have no idea when Chrysler started offering cruise with a manual.
Re: Cruise control with 4spd [Re: mopargem] #2573309
11/03/18 02:00 AM
11/03/18 02:00 AM
Cold Spring, NY
1970GTX Offline
1970GTX  Offline
Cold Spring, NY
I was able to order my 1986 Dodge Ramcharger with 4 speed and cruise.
The only combo I couldn't get was tilt wheel and 4 speed.
Re: Cruise control with 4spd [Re: MasterDeBaTeR !] #2573553
11/03/18 07:01 PM
11/03/18 07:01 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
http://www.dakotadigital.com/index.cfm/page/ptype=results/category_id=477/mode=cat/cat477.htm
I used one of these on my SRT8CUDA
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
