Motorhome 727 #2571078
10/29/18 04:49 PM
10/29/18 04:49 PM
Fulton County, PA
CMcAllister Offline OP
Mr. Helpful
Mr. Helpful
Fulton County, PA
WIW - BB 727 core out of a motorhome with the short tailshaft and park brake rig on the back. Not trying to sell one, just asking.
Re: Motorhome 727 [Re: CMcAllister] #2571406
10/30/18 01:41 AM
10/30/18 01:41 AM
Me too
Re: Motorhome 727 [Re: RapidRobert] #2571415
10/30/18 02:01 AM
10/30/18 02:01 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I had one I was tripping over in my shop so I gave it to my buddy who builds transmissions.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Motorhome 727 [Re: CMcAllister] #2571437
10/30/18 03:36 AM
10/30/18 03:36 AM
What ever you can get for it up
I'm thinking of using a short tail shaft class C M.H. 727 tranny without the brake on the back in my next bracket car with a driveshaft yoke that bolts onto the rear of the yoke in the tranny that has a splined female output to use like some of the pickups use to use work shruggy
Re: Motorhome 727 [Re: Cab_Burge] #2571471
10/30/18 09:33 AM
10/30/18 09:33 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ive had some of those and found that they are usually worth as much as they weigh.
Re: Motorhome 727 [Re: CMcAllister] #2571578
10/30/18 01:22 PM
10/30/18 01:22 PM
ohio
67mprfan Online content
67mprfan  Online Content
ohio
My transmission builder say some have low gear sets in them not for sure if it's true
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Motorhome 727 [Re: CMcAllister] #2571608
10/30/18 02:26 PM
10/30/18 02:26 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
727's all have the same 2.45/1.45
Re: Motorhome 727 [Re: 135sohc] #2571622
10/30/18 03:08 PM
10/30/18 03:08 PM
iagree up
Some of the HD 6 cylinder 904 tranny had low gear sets in them shruggy
Re: Motorhome 727 [Re: CMcAllister] #2571655
10/30/18 04:07 PM
10/30/18 04:07 PM
A727Tflite Offline
A727Tflite  Offline
Chrysler never made a production low gear set for any 727.
Only the race program offered them through Direct Connection.
Later model 904/998/999 had low gear sets in them.
Re: Motorhome 727 [Re: CMcAllister] #2571673
10/30/18 04:34 PM
10/30/18 04:34 PM
AndyF Offline
AndyF  Offline
I don't think they are worth much based on the fact that I see them in the local craigslist for sale on a regular basis.
Re: Motorhome 727 [Re: CMcAllister] #2571743
10/30/18 07:05 PM
10/30/18 07:05 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
Well, in that case, I guess it's worth the front half of a normal BB727.
Re: Motorhome 727 [Re: CMcAllister] #2571797
10/30/18 09:19 PM
10/30/18 09:19 PM
A727Tflite Offline
A727Tflite  Offline
iagree
Re: Motorhome 727 [Re: CMcAllister] #2571820
10/30/18 09:56 PM
10/30/18 09:56 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Good for a Gearvendors build if you want to reduce the overall length of the trans if it uses the same output shaft as the one without the E-brake.
Kevin
Re: Motorhome 727 [Re: Twostick] #2571827
10/30/18 10:06 PM
10/30/18 10:06 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Kevin
Most likely 4 pinion planetaries as well.
'63 Dodge 330
11.19 @ 121 mph
