Motorhome 727
#2571078
10/29/18 04:49 PM
10/29/18 04:49 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
WIW - BB 727 core out of a motorhome with the short tailshaft and park brake rig on the back. Not trying to sell one, just asking.
Re: Motorhome 727
[Re: RapidRobert]
#2571415
10/30/18 02:01 AM
10/30/18 02:01 AM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I had one I was tripping over in my shop so I gave it to my buddy who builds transmissions.
Re: Motorhome 727
[Re: CMcAllister]
#2571437
10/30/18 03:36 AM
10/30/18 03:36 AM
Posts: 43,124 Bend,OR USA
Cab_Burge
WIW - BB 727 core out of a motorhome with the short tailshaft and park brake rig on the back. Not trying to sell one, just asking. What ever you can get for it I'm thinking of using a short tail shaft class C M.H. 727 tranny without the brake on the back in my next bracket car with a driveshaft yoke that bolts onto the rear of the yoke in the tranny that has a splined female output to use like some of the pickups use to use
Re: Motorhome 727
[Re: CMcAllister]
#2571578
10/30/18 01:22 PM
10/30/18 01:22 PM
Posts: 1,030 ohio
67mprfan
ohio
My transmission builder say some have low gear sets in them not for sure if it's true
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
Re: Motorhome 727
[Re: 135sohc]
#2571622
10/30/18 03:08 PM
10/30/18 03:08 PM
Cab_Burge
727's all have the same 2.45/1.45 Some of the HD 6 cylinder 904 tranny had low gear sets in them
Re: Motorhome 727
[Re: CMcAllister]
#2571743
10/30/18 07:05 PM
10/30/18 07:05 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Well, in that case, I guess it's worth the front half of a normal BB727.
Re: Motorhome 727
[Re: Twostick]
#2571827
10/30/18 10:06 PM
10/30/18 10:06 PM
Posts: 4,669 Wichita
GY3
Wichita
Good for a Gearvendors build if you want to reduce the overall length of the trans if it uses the same output shaft as the one without the E-brake.
Kevin Most likely 4 pinion planetaries as well.
