Viscous thermal clutch for A/C car? #2569604
10/26/18 01:15 AM
10/26/18 01:15 AM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
When it comes to viscous clutches why is a thermal clutch best for A/C car?
Re: Viscous thermal clutch for A/C car? [Re: fatsat] #2569839
10/26/18 05:21 PM
10/26/18 05:21 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Is the heat coming off the a/c condenser enough to engage the thermal clutch? I would think if you did an R134A conversion with an original condenser a clutch fan could be counter productive to low speed a/c cooling.
Re: Viscous thermal clutch for A/C car? [Re: fatsat] #2569896
10/26/18 07:22 PM
10/26/18 07:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A/C puts more heat load on the radiator so the thermal clutch decreases the slippage to increase fan speed when a higher temp is sensed. A non-thermal clutch slippage stays the same regardless of temperature.
Re: Viscous thermal clutch for A/C car? [Re: fatsat] #2569905
10/26/18 07:34 PM
10/26/18 07:34 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
And don't store an OEM A/C clutch fan horizontally... at least not one for a 1965... keep it vertical or the fluid will leak out. DAMHIK.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Viscous thermal clutch for A/C car? [Re: 67SATisfaction] #2570273
10/27/18 04:49 PM
10/27/18 04:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
- Art
Hmm, I think you had a bad clutch that had nothing to do with how it was stored. After all, how is is stored in the vehicle when not in use? Horizontally.
Don't be the exception.
Re: Viscous thermal clutch for A/C car? [Re: 67SATisfaction] #2570317
10/27/18 07:22 PM
10/27/18 07:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What position is the clutch in when you open a new box with the printing up?
Re: Viscous thermal clutch for A/C car? [Re: fatsat] #2570403
10/27/18 10:51 PM
10/27/18 10:51 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Not just thermal but also Heavy duty is the correct one
Re: Viscous thermal clutch for A/C car? [Re: Supercuda] #2570577
10/28/18 01:28 PM
10/28/18 01:28 PM
moparx Offline
moparx  Offline
- Art
um, i hate to bring this up, but when on the car, the fan and clutch are "vertical" [up and down]. horizontal is "side to side", like the horizon. unless, of course, you have the assembly off and tossed into the trunk [for storage] horizontally. biggrin
beer
Re: Viscous thermal clutch for A/C car? [Re: fatsat] #2570607
10/28/18 03:06 PM
10/28/18 03:06 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You see Nacho's post right above yours? That clutch is vertical. That is NOT how it's installed in the car. Rotate the centerline 90 degrees and that is how it's installed, horizontally.
Re: Viscous thermal clutch for A/C car? [Re: fatsat] #2570861
10/29/18 05:19 AM
10/29/18 05:19 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Viscous thermal clutch for A/C car? [Re: Supercuda] #2570956
10/29/18 12:55 PM
10/29/18 12:55 PM
moparx Offline
moparx  Offline
please show a pic of one installed, then we can continue. biggrin
natcho's pic shows the clutch spring retainer and opposite side in the horizontal/side to side position. rotated 90* puts it at the vertical/up and down position, as is the assembly positioned on the car.
beer
Re: Viscous thermal clutch for A/C car? [Re: fatsat] #2571176
10/29/18 07:27 PM
10/29/18 07:27 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I'm just showing the front face of the correct clutch for AC cars, without any brass plate in front ( with or without thermal spring setup ), but the full aluminium disipation setup.
About the rest, I think this is going far out of any logic LOL. The horizontal position requirement is just while is storaged, not mounted. Once is mounted, the clutch is vertical no matter what!
Once is mounted that's not valid anymore. Spring will spin, thermal system will spin with fan and pump ( faster or slower, dragging less or more due the temp, doesn't matter ), so I'm not getting the deal of what you are talking about the spring "indexing"... or whatever else you are talking about! LOL
Re: Viscous thermal clutch for A/C car? [Re: fatsat] #2571202
10/29/18 08:12 PM
10/29/18 08:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
How do you think the clutch is mounted vertically? It's center line is horizontal not vertical, The mounting surface for the fan is vertical, but the clutch isn't.
Re: Viscous thermal clutch for A/C car? [Re: 67SATisfaction] #2571323
10/29/18 10:58 PM
10/29/18 10:58 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
- Art
Funny thing but I was also taught by my auto shop teacher in high school to always keep the thermal clutch fan in the vertical position just as it is installed on the car. We were also taught it will leak if not and I also believe I read it in a Mopar manual sometime over the 24 plus years I worked at a Dodge dealer. Will it leak if you lay it down ?? I don't know because I usually sit them in the same position as on the car only because I was taught that in 1972 in auto shop. Am I right ?? Good question but I can say they never leaked on me. smile Ron
Re: Viscous thermal clutch for A/C car? [Re: fatsat] #2571340
10/29/18 11:29 PM
10/29/18 11:29 PM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
On a side note...
Not sure if anyone experienced the same, but that Hayden clutch pictured did not work on a stock ('70 440) engine with A/C. The overall height of the clutch is very similar to the original "short shaft" clutches, however the distance between the fan mating surface and the water pump mating surface is less. This ends up placing the fan closer to the engine, nearly hitting the idler pulley. There was less than 1/8" of clearance, and this is with stock components.
I switched to a "456" repro clutch from Tony's. Sure, it's a lot more expensive, but at least it has the correct dimensions.
Re: Viscous thermal clutch for A/C car? [Re: fatsat] #2571375
10/30/18 12:31 AM
10/30/18 12:31 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I didn't say that's the correct PN for the application, just posted the pic to show how does look the heavy duty unit for AC.
Re: Viscous thermal clutch for A/C car? [Re: 383man] #2571379
10/30/18 12:35 AM
10/30/18 12:35 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
- Art
I remember have read on one or more of the clutches instructions sheets or packages I have bought about storage it horizontally. On the original package perspective is laying up or down, not the axis.
Re: Viscous thermal clutch for A/C car? [Re: Supercuda] #2571382
10/30/18 12:41 AM
10/30/18 12:41 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
now I got what you meant, but still I don't think is about the axis/centerline.
Re: Viscous thermal clutch for A/C car? [Re: NachoRT74] #2571856
10/30/18 10:47 PM
10/30/18 10:47 PM
Australia
fullonmopar Offline
fullonmopar  Offline
Australia
So why after all this confusing discussion why do the EATON brand clutch fans I have in long term storage are clearly stamped 'STORE WITH THIS FACE DOWN' In other words the flat or thermal face down, I think I will follow the instructions from the manufacturer.
Re: Viscous thermal clutch for A/C car? [Re: Supercuda] #2572069
10/31/18 12:29 PM
10/31/18 12:29 PM
moparx Offline
moparx  Offline
How do you think the clutch is mounted vertically? It's CENTER LINE is horizontal not vertical
i most certainly agree with this, as is the center line of the crank shaft, alternator, water pump, and power steering pump. however, just like a flywheel and clutch/pressure assembly, the mounting position of these components are/is considered to be on the vertical plane. the center line of these components, however, is still in the HORIZONTAL plane, which is different than the mounting position.
beer
