Re: Viscous thermal clutch for A/C car?
[Re: fatsat]
#2569896
10/26/18 07:22 PM
10/26/18 07:22 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A/C puts more heat load on the radiator so the thermal clutch decreases the slippage to increase fan speed when a higher temp is sensed. A non-thermal clutch slippage stays the same regardless of temperature.
[Re: fatsat]
#2569905
10/26/18 07:34 PM
10/26/18 07:34 PM
Posts: 7,541 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
And don't store an OEM A/C clutch fan horizontally... at least not one for a 1965... keep it vertical or the fluid will leak out. DAMHIK. - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: 67SATisfaction]
#2570273
10/27/18 04:49 PM
10/27/18 04:49 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
And don't store an OEM A/C clutch fan horizontally... at least not one for a 1965... keep it vertical or the fluid will leak out. DAMHIK. - Art Hmm, I think you had a bad clutch that had nothing to do with how it was stored. After all, how is is stored in the vehicle when not in use? Horizontally.
#2570317
10/27/18 07:22 PM
10/27/18 07:22 PM
John_Kunkel
Rio Linda, CA
And don't store an OEM A/C clutch fan horizontally What position is the clutch in when you open a new box with the printing up?
[Re: fatsat]
#2570403
10/27/18 10:51 PM
10/27/18 10:51 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
When it comes to viscous clutches why is a thermal clutch best for A/C car? Not just thermal but also Heavy duty is the correct one
[Re: Supercuda]
#2570577
10/28/18 01:28 PM
10/28/18 01:28 PM
Posts: 19,499 north of coder
moparx
And don't store an OEM A/C clutch fan horizontally... at least not one for a 1965... keep it vertical or the fluid will leak out. DAMHIK. - Art Hmm, I think you had a bad clutch that had nothing to do with how it was stored. After all, how is is stored in the vehicle when not in use? Horizontally. um, i hate to bring this up, but when on the car, the fan and clutch are "vertical" [up and down]. horizontal is "side to side", like the horizon. unless, of course, you have the assembly off and tossed into the trunk [for storage] horizontally.
[Re: fatsat]
#2570607
10/28/18 03:06 PM
10/28/18 03:06 PM
Supercuda
About to go away
About to go away
up yours
You see Nacho's post right above yours? That clutch is vertical. That is NOT how it's installed in the car. Rotate the centerline 90 degrees and that is how it's installed, horizontally.
[Re: fatsat]
#2571176
10/29/18 07:27 PM
10/29/18 07:27 PM
NachoRT74
Valencia, España
I'm just showing the front face of the correct clutch for AC cars, without any brass plate in front ( with or without thermal spring setup ), but the full aluminium disipation setup.
About the rest, I think this is going far out of any logic LOL. The horizontal position requirement is just while is storaged, not mounted. Once is mounted, the clutch is vertical no matter what!
Once is mounted that's not valid anymore. Spring will spin, thermal system will spin with fan and pump ( faster or slower, dragging less or more due the temp, doesn't matter ), so I'm not getting the deal of what you are talking about the spring "indexing"... or whatever else you are talking about! LOL
[Re: fatsat]
#2571202
10/29/18 08:12 PM
10/29/18 08:12 PM
Supercuda
About to go away
About to go away
up yours
How do you think the clutch is mounted vertically? It's center line is horizontal not vertical, The mounting surface for the fan is vertical, but the clutch isn't.
#2571323
10/29/18 10:58 PM
10/29/18 10:58 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
And don't store an OEM A/C clutch fan horizontally... at least not one for a 1965... keep it vertical or the fluid will leak out. DAMHIK. - Art Funny thing but I was also taught by my auto shop teacher in high school to always keep the thermal clutch fan in the vertical position just as it is installed on the car. We were also taught it will leak if not and I also believe I read it in a Mopar manual sometime over the 24 plus years I worked at a Dodge dealer. Will it leak if you lay it down ?? I don't know because I usually sit them in the same position as on the car only because I was taught that in 1972 in auto shop. Am I right ?? Good question but I can say they never leaked on me. Ron
[Re: fatsat]
#2571340
10/29/18 11:29 PM
10/29/18 11:29 PM
Posts: 2,311 NJ, USA
bill440rt
NJ, USA
On a side note... Not sure if anyone experienced the same, but that Hayden clutch pictured did not work on a stock ('70 440) engine with A/C. The overall height of the clutch is very similar to the original "short shaft" clutches, however the distance between the fan mating surface and the water pump mating surface is less. This ends up placing the fan closer to the engine, nearly hitting the idler pulley. There was less than 1/8" of clearance, and this is with stock components. I switched to a "456" repro clutch from Tony's. Sure, it's a lot more expensive, but at least it has the correct dimensions.
[Re: fatsat]
#2571375
10/30/18 12:31 AM
10/30/18 12:31 AM
NachoRT74
Valencia, España
I didn't say that's the correct PN for the application, just posted the pic to show how does look the heavy duty unit for AC.
[Re: 383man]
#2571379
10/30/18 12:35 AM
10/30/18 12:35 AM
NachoRT74
Valencia, España
And don't store an OEM A/C clutch fan horizontally... at least not one for a 1965... keep it vertical or the fluid will leak out. DAMHIK. - Art Funny thing but I was also taught by my auto shop teacher in high school to always keep the thermal clutch fan in the vertical position just as it is installed on the car. We were also taught it will leak if not and I also believe I read it in a Mopar manual sometime over the 24 plus years I worked at a Dodge dealer. Will it leak if you lay it down ?? I don't know because I usually sit them in the same position as on the car only because I was taught that in 1972 in auto shop. Am I right ?? Good question but I can say they never leaked on me. Ron I remember have read on one or more of the clutches instructions sheets or packages I have bought about storage it horizontally. On the original package perspective is laying up or down, not the axis.
[Re: Supercuda]
#2571382
10/30/18 12:41 AM
10/30/18 12:41 AM
NachoRT74
Valencia, España
How do you think the clutch is mounted vertically? It's center line is horizontal not vertical, The mounting surface for the fan is vertical, but the clutch isn't. now I got what you meant, but still I don't think is about the axis/centerline.
[Re: NachoRT74]
#2571856
10/30/18 10:47 PM
10/30/18 10:47 PM
Posts: 421 Australia
fullonmopar
Australia
So why after all this confusing discussion why do the EATON brand clutch fans I have in long term storage are clearly stamped 'STORE WITH THIS FACE DOWN' In other words the flat or thermal face down, I think I will follow the instructions from the manufacturer.
[Re: Supercuda]
#2572069
10/31/18 12:29 PM
10/31/18 12:29 PM
moparx
How do you think the clutch is mounted vertically? It's CENTER LINE is horizontal not vertical i most certainly agree with this, as is the center line of the crank shaft, alternator, water pump, and power steering pump. however, just like a flywheel and clutch/pressure assembly, the mounting position of these components are/is considered to be on the vertical plane. the center line of these components, however, is still in the HORIZONTAL plane, which is different than the mounting position.
