forque thrust wheels #2571098
10/29/18 05:16 PM
10/29/18 05:16 PM
Suffolk,VA
dragracedr Offline OP
Suffolk,VA
I have a 1965 Coronet - 528 Hemi, 4-link, 2875 race weight. 60 foot times 1.26 to 1.34 depending on track prep (NHRA prep vs local). Best e.t. 9.19@144, usually 9.38@139. Currently running Convo pros (12" wide) on the rear with 31x13MT bias slicks. I have a pair of American Torque thrust D 15x14 rear wheels. I'd like to run the Torque thrusts due to the Nostalgia look but I am concerned about the strength of the cast aluminum center section combined with the steel hoop. eventually this will be a 8.90 car. The question is are the Torque thrusts safe and reliable at these ET's/speeds? Any recommendations/experience?
Re: forque thrust wheels [Re: dragracedr] #2571183
10/29/18 07:37 PM
10/29/18 07:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Torque Thrust D with a steel hoop?
Re: forque thrust wheels [Re: John_Kunkel] #2571196
10/29/18 07:58 PM
10/29/18 07:58 PM
Suffolk,VA
Suffolk,VA
Yes.
Re: forque thrust wheels [Re: dragracedr] #2571276
10/29/18 09:59 PM
10/29/18 09:59 PM
Suffolk,VA
Suffolk,VA
Yes.
whoops, sorry. Aluminum hoop. I'm having a hard time multi-tasking
Re: forque thrust wheels [Re: dragracedr] #2571494
10/30/18 10:56 AM
10/30/18 10:56 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
a couple years ago I wanted to run my 64 polara at the meltdown drags, they are super picky about wheels and tires. I liked the torque thrust style wheel, and had the same concerns. I posted on a couple sites and had a few that ran the wheels with no problems. My car has run a best of a 9.64 & 135 3200lbs and a 1.35 60 foot for two years on the torque thrust wheels and so far no issues. And I get a lot of comments on how good the car looks with them.
Re: forque thrust wheels [Re: dragracedr] #2571500
10/30/18 11:11 AM
10/30/18 11:11 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run original American 200S on mine. Car has been 1.240/9.00@150. Weighs 3345-3470 depending on ballast. 6 years and 600 passes so far. It runs 1/2"studs which are watched and kept at 110lb/ft torque.
Doug
Re: forque thrust wheels [Re: dvw] #2571512
10/30/18 11:32 AM
10/30/18 11:32 AM
Suffolk,VA
Suffolk,VA
Thanks for the replies, guys. I feel much better now about these wheels. I'll mount 'em and use them for Nostalgia events and use the Convo pros for NHRA Super Street events. The Torque Thrusts sure are heavy. I run 5/8" rear studs
