Re: 9 sec. Pump gas, N/A small block [Re: W5DART66] #2570297
10/27/18 06:08 PM
10/27/18 06:08 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Some guys fudge the pump gas a little. 92-93 is readily available to most guys and should be what is used for examples. Heck I think even Dom uses 100 octane now in his Dart. Then comes track altitude as we all know the coastal states pump out some great numbers especially in the Fall.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 9 sec. Pump gas, N/A small block [Re: W5DART66] #2570300
10/27/18 06:22 PM
10/27/18 06:22 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Originally Posted By W5DART66
My 2009 engine masters motor went 9.60s in a street car 140mph 3100lbs 396"
That engine made 660 HP at 7000 rpm
Still running in a D50 down south drives it to the track.
Second car was Brads 422" w9 motor
Was built for spray and we went 9.40s on pump gas 140mph
3150 lbs
I don't feel it's hard to run mid 9s in 2900-3100 lbs car. On pump gas
The pump gas 457" deal I just did should run low 9s
I was at 3215 when I ran those numbers. It was 1.36 / 6.09 / 9.46@142.
Drove it all over and ran 9.40/9.50s at Atco, Cecil, Maple Grove in the summer heat. Would slow the car down to race 10.0 index.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 9 sec. Pump gas, N/A small block [Re: 1967dartgt] #2570495
10/28/18 06:44 AM
10/28/18 06:44 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Mine is 394 ci. 10.9 comp. 360-2 Indy heads , roller cam. Made 662 hp and 533 tq. On 91 octane. It is the motor Brett Miller mentioned in his post.
So far 1.33 60ft. 6.21 @ 110 in the 1/8. Driving to track on drag radials and mufflers. Still has more in it. Needs alot of work on carburetor.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 9 sec. Pump gas, N/A small block [Re: mshred] #2570502
10/28/18 08:53 AM
10/28/18 08:53 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
in street tune we done a 436 ci made 600 ftlb and 798hp with the headers used in the car which are a bit small at I only twisted it to 7000 rpm!
Nice happy little w9 436 cube small block 98 pump gas here at 3550 lbs a bit heavier than most of you guys runs 9.7 @ 140 with a bit more sorting to do
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: 9 sec. Pump gas, N/A small block [Re: pittsburghracer] #2570553
10/28/18 12:25 PM
10/28/18 12:25 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Originally Posted By pittsburghracer
Originally Posted By Dragula
Eazy Peezy with a G3 Hemi at 3000lbs...
Lol πŸ˜‚. Yaaaaa right.
It is.......Except I'm using a B-Body. 70 Road Runner, 3290 lbs, 401" Gen 3, pump gas 93, NA, driven to church on Sundays, 9.64 @ 137.6 mph, 1.29 60ft.
Re: 9 sec. Pump gas, N/A small block [Re: mshred] #2570557
10/28/18 12:38 PM
10/28/18 12:38 PM
Earth
Rob C Offline
Rob C  Offline
Earth
How much does your ride weigh in at?
Pittsburgh racers car is a great example of how a serious diet can help. If your street driving as well, then perhaps Lexan glass replacement would be a bit far, your call, I won’t bother going that far.
There is a good stickey at FABO here β€”> https://www.forabodiesonly.com/mopar/threads/post-your-9second-and-quicker-combos-here.89036/
Re: 9 sec. Pump gas, N/A small block [Re: mshred] #2570636
10/28/18 04:15 PM
10/28/18 04:15 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Cut weight (you can get quite far over time if you are willing to pay for it without ending up with a tincan) where you can do it is the best thing to do.
And that goes both for yourself and the car. Ok admitedly i dont have a clue if you got some exessbody weight but anyway.
Re: 9 sec. Pump gas, N/A small block [Re: Rob C] #2570667
10/28/18 05:42 PM
10/28/18 05:42 PM
PA.
"Little"John
"Little"John
PA.
Lol my car is getting fatter. I fired my skinny driver after I wrecked my Daytona and took over driving duties. Sold the fiberglass doors and went to stock doors with wind up windows, alternator, RacePak, R3 block, and a few other goodies. It sure is an easy car to go Racing with.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 9 sec. Pump gas, N/A small block [Re: pittsburghracer] #2571396
10/30/18 01:16 AM
10/30/18 01:16 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Little video of the engine from out side.
This is on pump gas πŸ‘πŸ»
https://youtu.be/LfHPKtZXB_k
