Re: 9 sec. Pump gas, N/A small block
[Re: W5DART66]
#2570297
10/27/18 06:08 PM
10/27/18 06:08 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Some guys fudge the pump gas a little. 92-93 is readily available to most guys and should be what is used for examples. Heck I think even Dom uses 100 octane now in his Dart. Then comes track altitude as we all know the coastal states pump out some great numbers especially in the Fall.
[Re: W5DART66]
#2570300
10/27/18 06:22 PM
10/27/18 06:22 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
My 2009 engine masters motor went 9.60s in a street car 140mph 3100lbs 396" That engine made 660 HP at 7000 rpm Still running in a D50 down south drives it to the track.
Second car was Brads 422" w9 motor Was built for spray and we went 9.40s on pump gas 140mph 3150 lbs
I don't feel it's hard to run mid 9s in 2900-3100 lbs car. On pump gas The pump gas 457" deal I just did should run low 9s
I was at 3215 when I ran those numbers. It was 1.36 / 6.09 / 9.46@142. Drove it all over and ran 9.40/9.50s at Atco, Cecil, Maple Grove in the summer heat. Would slow the car down to race 10.0 index.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#2570495
10/28/18 06:44 AM
10/28/18 06:44 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Mine is 394 ci. 10.9 comp. 360-2 Indy heads , roller cam. Made 662 hp and 533 tq. On 91 octane. It is the motor Brett Miller mentioned in his post. So far 1.33 60ft. 6.21 @ 110 in the 1/8. Driving to track on drag radials and mufflers. Still has more in it. Needs alot of work on carburetor.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: pittsburghracer]
#2570553
10/28/18 12:25 PM
10/28/18 12:25 PM
Posts: 3,875 Smyrna, South Carolina
STEFF
Eazy Peezy with a G3 Hemi at 3000lbs... Lol π. Yaaaaa right. It is.......Except I'm using a B-Body. 70 Road Runner, 3290 lbs, 401" Gen 3, pump gas 93, NA, driven to church on Sundays, 9.64 @ 137.6 mph, 1.29 60ft.
[Re: Rob C]
#2570667
10/28/18 05:42 PM
10/28/18 05:42 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Lol my car is getting fatter. I fired my skinny driver after I wrecked my Daytona and took over driving duties. Sold the fiberglass doors and went to stock doors with wind up windows, alternator, RacePak, R3 block, and a few other goodies. It sure is an easy car to go Racing with.
