Mopar Intake difference P4876337 vs. P4876128 #2569635
10/26/18 06:32 AM
10/26/18 06:32 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Mopar Intake difference P4876337 vs. P4876128?
Photos and description appear the same. Any difference?
The P4876128 RB single plane is priced really good < $250
http://www.moparonlineperformance.com/product-p/p4876128.htm
http://www.moparonlineperformance.com/product-p/p4876337.htm
Re: Mopar Intake difference P4876337 vs. P4876128 [Re: 451Mopar] #2569642
10/26/18 08:53 AM
10/26/18 08:53 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The '128 intake is only for Stage VI heads, as it eliminates the need for intake spacers to use this intake on an RB block.
It doesn't work for any other combination of which I'm aware (and I owned the standard-port version at one time). Also, not a very good intake without significant work having been done.
Re: Mopar Intake difference P4876337 vs. P4876128 [Re: 451Mopar] #2569864
10/26/18 06:16 PM
10/26/18 06:16 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Significant as in port matching, or something more?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Mopar Intake difference P4876337 vs. P4876128 [Re: 451Mopar] #2569878
10/26/18 07:01 PM
10/26/18 07:01 PM
AndyF Offline
AndyF  Offline
I saw the other day that they were giving that 128 intake away. Sadly it is practically useless since only a few guys still have Stage VI heads on anything.
Re: Mopar Intake difference P4876337 vs. P4876128 [Re: BloFish] #2569907
10/26/18 07:40 PM
10/26/18 07:40 PM
BradH Offline
BradH  Offline
laugh2
Yeah, I suppose "something more" would start to describe it. sawzall + weld + hammer would be a good start.
Re: Mopar Intake difference P4876337 vs. P4876128 [Re: 451Mopar] #2569922
10/26/18 08:22 PM
10/26/18 08:22 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Its pretty cut and dried.......
If you have MW size stage VI heads on your RB block, the 128 intake fits that combination of parts.
And nothing else.
The 337 intake is for MW sized ports with heads that don't have raised ports......like factory MW heads, or Edelbrock RPM heads that have been opened up to MW size.
It eliminates the need for a separate valley pan gasket, since it seals off the valley with a plate cast onto the bottom.
It can be used on some raised port heads as well(Indy, Victor, TF270, etc), but there will be a gap between the block end rails and the built in valley plate.
Re: Mopar Intake difference P4876337 vs. P4876128 [Re: 451Mopar] #2570038
10/27/18 12:34 AM
10/27/18 12:34 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Thanks. Wondered why it was so cheap?
Re: Mopar Intake difference P4876337 vs. P4876128 [Re: 451Mopar] #2570871
10/29/18 09:00 AM
10/29/18 09:00 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
I just removed an Indy 2D and finally installed my newly ported 337 from Larry Smith on my Indy headed RB and what a difference! Whoa!
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Mopar Intake difference P4876337 vs. P4876128 [Re: 451Mopar] #2570955
10/29/18 12:54 PM
10/29/18 12:54 PM
So. Burlington, Vt.
So. Burlington, Vt.
It’s like a few other tidbits from MP that was actually a good piece, for a reasonable price.
So.......naturally, you can’t get them anymore.
