Re: Mopar Intake difference P4876337 vs. P4876128
[Re: 451Mopar]
#2569642
10/26/18 08:53 AM
10/26/18 08:53 AM
BradH
The '128 intake is only for Stage VI heads, as it eliminates the need for intake spacers to use this intake on an RB block.
It doesn't work for any other combination of which I'm aware (and I owned the standard-port version at one time). Also, not a very good intake without significant work having been done.
[Re: 451Mopar]
#2569864
10/26/18 06:16 PM
10/26/18 06:16 PM
Posts: 16,495 On the run…
BloFish
On the run…
Significant as in port matching, or something more?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2569907
10/26/18 07:40 PM
10/26/18 07:40 PM
BradH
Significant as in port matching, or something more? Yeah, I suppose "something more" would start to describe it. + + would be a good start.
[Re: 451Mopar]
#2569922
10/26/18 08:22 PM
10/26/18 08:22 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Its pretty cut and dried.......
If you have MW size stage VI heads on your RB block, the 128 intake fits that combination of parts. And nothing else.
The 337 intake is for MW sized ports with heads that don't have raised ports......like factory MW heads, or Edelbrock RPM heads that have been opened up to MW size. It eliminates the need for a separate valley pan gasket, since it seals off the valley with a plate cast onto the bottom. It can be used on some raised port heads as well(Indy, Victor, TF270, etc), but there will be a gap between the block end rails and the built in valley plate.
[Re: 451Mopar]
#2570871
10/29/18 09:00 AM
10/29/18 09:00 AM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
I just removed an Indy 2D and finally installed my newly ported 337 from Larry Smith on my Indy headed RB and what a difference! Whoa!
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: 451Mopar]
#2570955
10/29/18 12:54 PM
10/29/18 12:54 PM
fast68plymouth
So. Burlington, Vt.
It’s like a few other tidbits from MP that was actually a good piece, for a reasonable price.
So.......naturally, you can’t get them anymore.
