Reproduction plastic liners for car doors? #2568719
10/24/18 04:07 AM
10/24/18 04:07 AM
Los Angeles, CA
JF_Moparts Offline OP
Los Angeles, CA
Hey all,
I took apart my car door (1971 Satellite) the other day and noticed that the plastic liners that were behind the door panels are gone. I've had the car for 31 years and I know they were there before I had some body work done, so I assume the shop lost the liners. Does anyone know if there's a place that repros those things? It was a pretty thick plastic, maybe plain old sheets of plastic are available?
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2568720
10/24/18 04:44 AM
10/24/18 04:44 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I bought some heavy clear plastic from Home Depot for a home project once to use as a vapor barrier after insulating between the studs. That would probably work.
Scott
1969 Super Bee, 383/4 speed
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2568730
10/24/18 07:03 AM
10/24/18 07:03 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Like he said, just get some thick plastic sheet and cut it to proper shape. I found that 3M spray adhesive in the right places worked the best. Just in case you didn't take it apart, the bottom gets tucked into the slots at the bottom of the door to direct any water in there instead of the floorpan.
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2568749
10/24/18 10:11 AM
10/24/18 10:11 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
I saw some listed on e-bag! Not sure what the price was.
Re: Reproduction plastic liners for car doors? [Re: hemirdrnnr] #2568758
10/24/18 10:47 AM
10/24/18 10:47 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Performance Car Graphics
Re: Reproduction plastic liners for car doors? [Re: RJS] #2568829
10/24/18 12:56 PM
10/24/18 12:56 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Little expensive...but look nice...
http://www.performancecargraphics.com/Door_Stuff/Moisture_Barrier.htm
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Reproduction plastic liners for car doors? [Re: JMCFAN] #2568958
10/24/18 04:14 PM
10/24/18 04:14 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I just answer the question at hand, and make no money!!!!LOL
Ron
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2568993
10/24/18 05:14 PM
10/24/18 05:14 PM
WA
tman Offline
tman  Offline
WA
These good enough? or just make your own.....
https://www.ebay.com/itm/1970-74-MoPar-Challanger-Cuda-door-panel-moisture-vapor-barriers/173556167277?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2569098
10/24/18 08:42 PM
10/24/18 08:42 PM
None
71rm23 Offline
71rm23  Offline
None
As noted, performancecargraphics.com and be done
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2569437
10/25/18 04:08 PM
10/25/18 04:08 PM
Los Angeles, CA
Los Angeles, CA
Thanks for the answers!
Re: Reproduction plastic liners for car doors? [Re: StukaJU87] #2569536
10/25/18 10:19 PM
10/25/18 10:19 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I went to HD and made my own.
Re: Reproduction plastic liners for car doors? [Re: 71birdJ68] #2569652
10/26/18 09:29 AM
10/26/18 09:29 AM
North Carolina
TommmyBoy Offline
TommmyBoy  Offline
North Carolina
Where do you buy the same black goop the factory used to hold the plastic in place, and what is the proper name for it?
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2569655
10/26/18 09:50 AM
10/26/18 09:50 AM
Mass
charge70 Offline
charge70  Offline
Mass
I use 3M Part# 08578 strip calk.Available at most parts stores.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2569738
10/26/18 01:29 PM
10/26/18 01:29 PM
70duster340 Offline
70duster340  Offline
Just curious, but would a spray rubber work as well?
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2569753
10/26/18 02:20 PM
10/26/18 02:20 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
Too messy...I used 3M weatherstrip adhesive.
When you work on Spaceships for a living, how bad can a workday be?
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2569771
10/26/18 03:06 PM
10/26/18 03:06 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I had an open tube of 3M 08509 Bedding & Glazing Compound (the butyl rubber stuff for our windshields and back glasses) so I just ran a bead around the areas I wanted the plastic to stick to, and pressed it into place up
The Weatherstrip Adhesive will stick very effectively, but it may be hard to ever remove the plastic again without destroying it. Same for double-sided foam tape, or contact cements...
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2569809
10/26/18 04:39 PM
10/26/18 04:39 PM
70duster340 Offline
70duster340  Offline
Not sure if you understood what I meant. I meant would it work covering the back of the door panels in the spray rubber? I would think that would be much easier and do a better job of waterproofing the door panels.
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2570021
10/26/18 11:56 PM
10/26/18 11:56 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
The plastic acts as a water barrier and a wind stop. It keeps the rain water that gets past the window seals from getting to the door panels, then redirects that water back inside the door so it can drain out the bottom of the door and not run inside to the panel and inside the car. It also helps keep outside air from entering the passenger compartment through the doors.
Our pampered cars can probably survive well without redirecting the water back into the doors to drain out the bottom, they likely won't see many hard rains. If you can live with not having everything as factory equipped, the do it your self process will work just great. Gene
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2570342
10/27/18 08:28 PM
10/27/18 08:28 PM
70duster340 Offline
70duster340  Offline
Thanks. I guess I would prefer to have the water directed out of the car. I would think that if the car were washed, the water would leak onto the floorboards, eventually causing rust to form. I could make my own, but my Duster didn't have any when I got it, so I don't have a template to work with.
Re: Reproduction plastic liners for car doors? [Re: JF_Moparts] #2570506
10/28/18 09:49 AM
10/28/18 09:49 AM
Mass
charge70 Offline
charge70  Offline
Mass
You can use the door panel as a start template and trim it down as needed
