Re: Reproduction plastic liners for car doors?
[Re: JF_Moparts]
#2568720
10/24/18 04:44 AM
10/24/18 04:44 AM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
I bought some heavy clear plastic from Home Depot for a home project once to use as a vapor barrier after insulating between the studs. That would probably work.
Scott
1969 Super Bee, 383/4 speed
[Re: JF_Moparts]
#2568730
10/24/18 07:03 AM
10/24/18 07:03 AM
Posts: 4,462 Morristown Tn.
71birdJ68
Morristown Tn.
Like he said, just get some thick plastic sheet and cut it to proper shape. I found that 3M spray adhesive in the right places worked the best. Just in case you didn't take it apart, the bottom gets tucked into the slots at the bottom of the door to direct any water in there instead of the floorpan.
[Re: hemirdrnnr]
#2568758
10/24/18 10:47 AM
10/24/18 10:47 AM
Posts: 6,224 JERSEY
RJS
JERSEY
[Re: JMCFAN]
#2568958
10/24/18 04:14 PM
10/24/18 04:14 PM
Posts: 6,224 JERSEY
RJS
JERSEY
I just answer the question at hand, and make no money!!!!LOL Ron
[Re: StukaJU87]
#2569536
10/25/18 10:19 PM
10/25/18 10:19 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I bought some heavy clear plastic from Home Depot for a home project once to use as a vapor barrier after insulating between the studs. That would probably work. I went to HD and made my own.
[Re: JF_Moparts]
#2569655
10/26/18 09:50 AM
10/26/18 09:50 AM
Posts: 603 Mass
charge70
Mass
I use 3M Part# 08578 strip calk.Available at most parts stores.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: JF_Moparts]
#2569753
10/26/18 02:20 PM
10/26/18 02:20 PM
Posts: 406 California City, CA
dart440
California City, CA
Too messy...I used 3M weatherstrip adhesive.
When you work on Spaceships for a living, how bad can a workday be?
[Re: JF_Moparts]
#2570506
10/28/18 09:49 AM
10/28/18 09:49 AM
Posts: 603 Mass
charge70
Mass
You can use the door panel as a start template and trim it down as needed
