Nodular 8.75 case , how much stronger
#2567293
10/21/18 01:58 PM
10/21/18 01:58 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
Than a production 489 housing Anybody using a nodular 8.75 rear with a brake?
Re: Nodular 8.75 case , how much stronger
[Re: B3422W5]
#2567355
10/21/18 04:05 PM
10/21/18 04:05 PM
B3422W5
Portage,michigan
Years ago i tore up a 489 case the first weekend out with a combo that made decent steam( at that time 10.40 in a 3350 pound car) after running high 10’s for several years with the previous combo and no issues. Should mention this is all footbrake. Just wondering if its worth spending 1000 or so on a new 3rd member with spool and the nodular to footbrake race something thats going to be making more steam than currently next season A Dana would be a bunch more than that, and welding brackets and this and that
[Re: Roughbird72]
#2567391
10/21/18 05:23 PM
10/21/18 05:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I ran a stock 742 forever as you know Cab and these new nodular units are better than the all mighty 742.......... Do they have more pinion support than stock cases? The biggest issue was most guys didnt put in a solid spacer in the 489 case.. the 742 has one ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: B3422W5]
#2567409
10/21/18 06:23 PM
10/21/18 06:23 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Ok I will say it, Do not waste more money on an 8 3/4, PERIOD
[Re: B3422W5]
#2567411
10/21/18 06:26 PM
10/21/18 06:26 PM
Posts: 4,457 Washington
madscientist
Washington
Do the Dana and don't look back. A bit more money now but cheaper in the long run.
[Re: B3422W5]
#2567427
10/21/18 07:03 PM
10/21/18 07:03 PM
Posts: 22,727 Bitopia
jcc
Bitopia
It seems to me, after decades of these discussions, the venerable 8.75 might be the best engineering design ever, in that when loaded beyond its design strength, EVERYTHING fails at nearly once, meaning from an engineering stand point, NOTHING is over designed/overweight/over cost.
All that means is, if you like playing wacko o mole, you are in the right place, keep reading, keep adding band aids..
It you are at or near the limits of a 8.75, that last poster is your guy.
[Re: CSK]
#2567429
10/21/18 07:06 PM
10/21/18 07:06 PM
Thumperdart
State of confusion
Ok I will say it, Do not waste more money on an 8 3/4, PERIOD Been driving racing my 9-second Dart forever and JUST replaced the "stock" pumpkin 2+ years ago that had stock caps bolts etc. Too many wives tales but then again, some people are puttin them in the wrong application so you need to know where the cut off point is...........
[Re: B3422W5]
#2567434
10/21/18 07:17 PM
10/21/18 07:17 PM
Posts: 4,212 New York
polyspheric
New York
Not that much if you sell the 8-3/4 while it's still good.
Boffin Emeritus
[Re: merpar]
#2567495
10/21/18 10:12 PM
10/21/18 10:12 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
The weak point in the 8 3/4 is the bearing caps. I thought it was the lack of a rear pinion support...
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: merpar]
#2567496
10/21/18 10:18 PM
10/21/18 10:18 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
The weak point in the 8 3/4 is the bearing caps. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Usually the left cap cracks and breaks into two or more pieces and sometimes it will break the passenger side cap at the same time ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) OP, pick your poison, pay more now for a Dana 60 or pay for one later ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I had three different 742 8 3/4 pumpkins as well as several 741 and 489 cases with solid spacer instead of the crush sleeve, I cracked the outer tips on the ring gear teeth on all of them and ended up bending the heck out of unbraced housing due launching the car hard for a lot of passes(200+) before it bent badly enough to break the welds off of the ladder bar mounts ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Luckily it broke them on the starting line, not going into 2nd or 3rd gear ![work work](/ubbthreads/images/graemlins/custom/work.gif) It broke a bunch of other drive line parts before bending the housing Looking back now I should have put a Dana 60 on it to start with, but I didn't ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif)
