Page 1 of 4 1 2 3 4
Nodular 8.75 case , how much stronger #2567293
10/21/18 01:58 PM
10/21/18 01:58 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Than a production 489 housing
Anybody using a nodular 8.75 rear with a brake?
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567303
10/21/18 02:20 PM
10/21/18 02:20 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
laugh2 This oughta be good
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567313
10/21/18 02:48 PM
10/21/18 02:48 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
popcorn
72 Plymouth Roadrunner 11.08@123.25
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567322
10/21/18 03:06 PM
10/21/18 03:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been running the Dr Diff unit for 2+ years and it is awesome imo and a bit heavier but beefier with forged caps and stout adjusters.........of course my stock unit lasted 16+ years........... boogie drive
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567355
10/21/18 04:05 PM
10/21/18 04:05 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Years ago i tore up a 489 case the first weekend out with a combo that made decent steam( at that time 10.40 in a 3350 pound car) after running high 10’s for several years with the previous combo and no issues. Should mention this is all footbrake.
Just wondering if its worth spending 1000 or so on a new 3rd member with spool and the nodular to footbrake race something thats going to be making more steam than currently next season
A Dana would be a bunch more than that, and welding brackets and this and that
1.41 best 60 foot
6.56 at 104.17
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567363
10/21/18 04:09 PM
10/21/18 04:09 PM
I was told years ago that all of the early 8 3/4 third members, probably those made before the 489 came out confused where cast steel which is a whole bunch stronger than either cast grey iron or cast nodular iron work scope
If I was you and insisted on running a 8 3/4 third member instead of a Dana 60 I would look for and buy a 742 case and add a steel cap with studs on the drivers side up twocents
Re: Nodular 8.75 case , how much stronger [Re: Cab_Burge] #2567380
10/21/18 04:42 PM
10/21/18 04:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ran a stock 742 forever as you know Cab and these new nodular units are better than the all mighty 742.......... biggrin beer
Re: Nodular 8.75 case , how much stronger [Re: Thumperdart] #2567387
10/21/18 05:08 PM
10/21/18 05:08 PM
Roughbird72 Offline
Roughbird72  Offline
Do they have more pinion support than stock cases?
Re: Nodular 8.75 case , how much stronger [Re: Roughbird72] #2567391
10/21/18 05:23 PM
10/21/18 05:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The biggest issue was most guys didnt put in a solid spacer
in the 489 case.. the 742 has one
wave
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567409
10/21/18 06:23 PM
10/21/18 06:23 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Ok I will say it, Do not waste more money on an 8 3/4, PERIOD
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567411
10/21/18 06:26 PM
10/21/18 06:26 PM
Washington
madscientist Offline
Washington
Do the Dana and don't look back. A bit more money now but cheaper in the long run.
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567427
10/21/18 07:03 PM
10/21/18 07:03 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
It seems to me, after decades of these discussions, the venerable 8.75 might be the best engineering design ever, in that when loaded beyond its design strength, EVERYTHING fails at nearly once, meaning from an engineering stand point, NOTHING is over designed/overweight/over cost.
All that means is, if you like playing wacko o mole, you are in the right place, keep reading, keep adding band aids..
It you are at or near the limits of a 8.75, that last poster is your guy.
Re: Nodular 8.75 case , how much stronger [Re: CSK] #2567429
10/21/18 07:06 PM
10/21/18 07:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been driving racing my 9-second Dart forever and JUST replaced the "stock" pumpkin 2+ years ago that had stock caps bolts etc. Too many wives tales but then again, some people are puttin them in the wrong application so you need to know where the cut off point is...........
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567434
10/21/18 07:17 PM
10/21/18 07:17 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Not that much if you sell the 8-3/4 while it's still good.
Boffin Emeritus
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567445
10/21/18 07:53 PM
10/21/18 07:53 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Several years ago my S-60 was $1940 shipped to my work (we have a dock) and I reused the brakes off my 8 3/4. My 8 3/4 was fresh, new bearings, gears, rebuilt clutch type sure grip and Moser bbp axles, I got $700 out of it with no brakes.
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567482
10/21/18 09:32 PM
10/21/18 09:32 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Here's the unit I got from Dr Diff a couple years ago.
2 kids and a dog
Re: Nodular 8.75 case , how much stronger [Re: TonyS451] #2567486
10/21/18 09:39 PM
10/21/18 09:39 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Replaced this. Sure looks stronger, but who knows. I always heard it was the pinion size that was the weakest point. I was mainly just changing ratio, but figured I'd make it strong as poss while I was at it.
2 kids and a dog
Re: Nodular 8.75 case , how much stronger [Re: B3422W5] #2567490
10/21/18 09:57 PM
10/21/18 09:57 PM
Nevada
merpar Offline
merpar  Offline
Nevada
The weak point in the 8 3/4 is the bearing caps.
Re: Nodular 8.75 case , how much stronger [Re: merpar] #2567495
10/21/18 10:12 PM
10/21/18 10:12 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I thought it was the lack of a rear pinion support...
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Nodular 8.75 case , how much stronger [Re: merpar] #2567496
10/21/18 10:18 PM
10/21/18 10:18 PM
iagree Usually the left cap cracks and breaks into two or more pieces and sometimes it will break the passenger side cap at the same time whiney
OP, pick your poison, pay more now for a Dana 60 or pay for one later work shruggy
I had three different 742 8 3/4 pumpkins as well as several 741 and 489 cases with solid spacer instead of the crush sleeve, I cracked the outer tips on the ring gear teeth on all of them and ended up bending the heck out of unbraced housing due launching the car hard for a lot of passes(200+) before it bent badly enough to break the welds off of the ladder bar mounts whiney shruggy Luckily it broke them on the starting line, not going into 2nd or 3rd gear work It broke a bunch of other drive line parts before bending the housing shruggy
Looking back now I should have put a Dana 60 on it to start with, but I didn't realcrazy
Page 1 of 4 1 2 3 4
