Re: Slight water drip behind motor plate....What to do
[Re: Cab_Burge]
#2566701
10/19/18 10:35 PM
10/19/18 10:35 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I usually run my engines for three years between rebuilding them and those plates leak after about 1 1/2 seasons. Tightening the bolts never help and sealers are a temporary fix and I end up removing the plate and sealing it the right way. Lots of torque on those plates. For now on every winter I am going to remove the plate as scheduled maintenance and be done with it.
[Re: MR_P_BODY]
#2566712
10/19/18 11:03 PM
10/19/18 11:03 PM
Challenger 1
Cincinnati, Ohio
Stop Leak.. I use a can of it on every engine I use Yes of course or the morso ceramic sealer like said above, but the ceramic seal is probably overkill. Nothing wrong with either.
[Re: 64hemi330sedan]
#2566922
10/20/18 02:13 PM
10/20/18 02:13 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
I use the gm block sealer tablets. I use these also with great results.
#2566933
10/20/18 02:57 PM
10/20/18 02:57 PM
Posts: 11,635 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I use the gm block sealer tablets. This is what I use, if I use anything. I hate putting any of that crap in my cooling system. I have used a smear of silicone to smooth and fill corrosion pits and other imperfections in old castings. Used FelPro gaskets, dry, on stuff on the front of the engine. Also, some teflon on the threads of fasteners going into a wet hole. Stays dry as a popcorn fart.
[Re: Sammy]
#2566936
10/20/18 03:04 PM
10/20/18 03:04 PM
Posts: 289 Lowes
steve660
Lowes
Put a board under oil pan then raise engine with floor jack. Dont have to raise it much, just enough to get weight off engine plate.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: steve660]
#2566943
10/20/18 03:23 PM
10/20/18 03:23 PM
Sammy
Wind Gap,Pa.
Put a board under oil pan then raise engine with floor jack. Dont have to raise it much, just enough to get weight off engine plate. This is what I was planning. Scares me to put this much weight with trans, attached on a aluminum pan. I'll go real slow.
[Re: Sammy]
#2567092
10/20/18 10:28 PM
10/20/18 10:28 PM
RapidRobert
A bottle jack & a board on each side, coming up to the pan bolts.
