Headers tips & tricks! #2563978
10/14/18 06:04 PM
10/14/18 06:04 PM
Sweden
ChallengerRag Offline OP
Sweden
Hi, as i might swap out mine original type iron headers your ideas of brands & recomendations are welcome.
Facts 71 Chally, 440six pack, auto trans, ps, pb, has the original a31 hp axle package, so discs in front, 3;91 sure grip, short ratio pitman is included. So this is ordered same as an RT but is an Conv.. was 340 now 440sp
Have looked at TTI 1-7/8 440 headers, think mini starter is a must but more? is it best throw in an slant six hehe.. any advice what headers to look for?
Michael
Stockholm
Re: Headers tips & tricks! [Re: ChallengerRag] #2563999
10/14/18 06:48 PM
10/14/18 06:48 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Car like that I wouldnt dream of any header other than TTI, Dougs or Schumacher. All above mentioned with ceramic coated are above $700. The Shumachers are easiest to install and work around but also are limited to 450 horsepower as stated by the MFGR. If it were my car Id go 1 7/8" Dougs or TTI.
Keep old mopars alive.
Re: Headers tips & tricks! [Re: ChallengerRag] #2564001
10/14/18 06:52 PM
10/14/18 06:52 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I'd stick with stock iron manifolds.
Re: Headers tips & tricks! [Re: ChallengerRag] #2564039
10/14/18 08:29 PM
10/14/18 08:29 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Unless you're planning other modifications I'd stick with stock manifolds on a car like that. You're not gonna get a big improvement in power with headers. Beautiful car by the way.
Re: Headers tips & tricks! [Re: ChallengerRag] #2564062
10/14/18 09:14 PM
10/14/18 09:14 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You will cuss the headers every time you try to work on anything.
Re: Headers tips & tricks! [Re: 71birdJ68] #2564105
10/14/18 10:12 PM
10/14/18 10:12 PM
USA
K
ksat Offline
ksat  Offline
K
USA
iagree
I've put headers and other aftermarket parts on my car and I've really gotten fed up with it all. Always one problem after another.
Re: Headers tips & tricks! [Re: ksat] #2564198
10/15/18 12:35 AM
10/15/18 12:35 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have Doug's 2" headers on my Savoy and they fit absolutely perfect even with a 4 speed. I have a steel bellhousing and I had to trim the edges so the tubes would clear. A stock bell would not be an issue.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Headers tips & tricks! [Re: ChallengerRag] #2564236
10/15/18 03:27 AM
10/15/18 03:27 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the 2" TTI on my car with its 440/493 and you can change the plugs with ease on it. One thing I like about headers also is the cool off much faster then the exh manifolds do and no matter what a car has I prefer to do plugs when its cooled off some. And I am a header guy as I like the more performance of the headers. The good headers like TTI and the Dougs have thick flanges and don't warp like the headers of the 70's did. Good luck . Ron
Re: Headers tips & tricks! [Re: ChallengerRag] #2564249
10/15/18 04:14 AM
10/15/18 04:14 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
TTI all the way, I have a set on the 451 in my Challenger and they fit great and make the engine 10-15% more HP.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Headers tips & tricks! [Re: Cudajon] #2564261
10/15/18 06:54 AM
10/15/18 06:54 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
This s so true but the hobby has to do with tinkering and trying new stuff.. I love the look of a high quality silver ceramic coated header.
Re: Headers tips & tricks! [Re: 2boltmain] #2564337
10/15/18 12:00 PM
10/15/18 12:00 PM
I like black coated up work
We are not all the same, shruggy
OP, if your a hot rodder at heart then you got to get the most performance out of that car you can, you don't want any SB Camaro convertible showing you its tail lights, do you stirthepot work shruggy
Re: Headers tips & tricks! [Re: ChallengerRag] #2564344
10/15/18 12:10 PM
10/15/18 12:10 PM
Kirkland, Washington
Pacnorthcuda Offline
I've run Hedman headers on 440 ebodies for the last 25 years. I did have to clearance for the power steering box on the last car (which I hated to do on brand new, Jet Hot Sterling coated headers, but the coating held fine).
Never a problem with leaks, ever. Also currently running a fast ratio pitman with no problems.
Re: Headers tips & tricks! [Re: ChallengerRag] #2564380
10/15/18 01:31 PM
10/15/18 01:31 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I still use Hooker Super Comps.
I've had the same gaskets on mine since circa 2003. I do use copper collector gaskets. Not a ton of miles in that time, I will admit, but when I take it out I seldom baby it. They work ok. I would never pay retail for them though.
Rich H.
Esse Quam Videri
Re: Headers tips & tricks! [Re: ChallengerRag] #2564391
10/15/18 01:52 PM
10/15/18 01:52 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Michael
Stockholm
If you never rev the motor past 4500 rpm, keep the cast iron manifolds. If anything add a set of Hooker Aero Chamber mufflers to give the car a deeper exhaust note.
Most of my friends in Stockholm and Finland have already put their cars away for the long winter. Rust from the inside out is an issue with headers that sit for long periods of time. Even if they are coated inside and out, which helps extend their life.
Get the full TTI exhaust if you are going to pull the trigger on upgrading your exhaust. It's the best, but pay for the inside and out coatings.
Re: Headers tips & tricks! [Re: ChallengerRag] #2564429
10/15/18 03:09 PM
10/15/18 03:09 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Michael
Stockholm
If that was my car i would get the TTI headers,after owning one set it was a nobrainer to buy TTI again when i decided i needed a bigger set.
Do the ceramiccoated inside and out.
Regarding ministarter or not,check the application notes from TTI but overall i like them anyway since they are smaller lighter and i guess they might need less power to start an engine due to not be of a stoneage design.
That looks like one fine car you have there!
Still a few nice cars on the roads before the long dark winter sets in!
Re: Headers tips & tricks! [Re: 1Fast340] #2564475
10/15/18 04:49 PM
10/15/18 04:49 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Headers if your going to keep it and use it.
If you plan on selling it manifolds are better for resale. As time goes on Mopar guys are becoming like vintage Vette/Shelby Mustang guys, who like original everything and quickly dismiss modded cars.
Re: Headers tips & tricks! [Re: ChallengerRag] #2564502
10/15/18 05:24 PM
10/15/18 05:24 PM
an8sec70cuda Offline
I like going fast so headers for me. If you do get headers, go with TTI.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Headers tips & tricks! [Re: ChallengerRag] #2564519
10/15/18 06:13 PM
10/15/18 06:13 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
headers like to hug the starter so much that you have to move them to get the couple apart. I'd stay with stock manifolds
I built a brand new motor and not being filthy rich,had one set of TTI's to install. The bummer was TTI stated NOT to install the headers on an engine to be broken in as it would ruin the ceramic coating. Nice
