73 three on da tree clutch replacement #2561883
10/10/18 12:33 PM
10/10/18 12:33 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
After 45 years and 79,000 Miles the Waygun's clutch is due.
318/ 3 speed manual column shift.
Can anybody tell me the specs for the clutch? 10.5? 11 inch?
I know the tranny is not the Hemi 18 spline but I see 23 and 26 spline listings.Which one do I have?
I plan on upgrading from stock since I have 4bbl intake and 800cfm ThermoQuad with dual exhaust.The engine will be getting an upgraded cam for a heavy car that will be towing.
Any advice and/or clutch recommendations is appreciated,thanks in advance.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: 73 three on da tree clutch replacement [Re: 68Cbarge] #2561957
10/10/18 03:10 PM
10/10/18 03:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There are no 26 spline clutches for that era. So where you are seeing this is not a good source.
It's a 10.5" 23 spline setup and just about any stock replacement kit will do what you need. If you want a lighter pedal feel the diaphragm option is available.
Don't be the exception.
Re: 73 three on da tree clutch replacement [Re: 68Cbarge] #2561958
10/10/18 03:10 PM
10/10/18 03:10 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Should be 23 spline 10 1/2.Every V8 ive seen is 123 unless hemi thats 18.Rocky
Chrysler Firepower
Re: 73 three on da tree clutch replacement [Re: 68Cbarge] #2562039
10/10/18 05:16 PM
10/10/18 05:16 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
Thanks guys!
Centerforce clutches are not cheap yet good but may be overkill for my heavy wagon with light engine upgrades.
I do city drive my Waygun and dont want to blow out my knee or hip,yet want a good grabbing clutch. LOL
I was considering Ram,Zoom,or MacLeod.
Any thoughts?
Re: 73 three on da tree clutch replacement [Re: 68Cbarge] #2562072
10/10/18 06:41 PM
10/10/18 06:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
As others have said, no need to break the bank, just get a slightly heavier stock replacement clutch.
https://www.rockauto.com/en/moreinfo.php?pk=334404&cc=1435014&jsn=422
Re: 73 three on da tree clutch replacement [Re: 68Cbarge] #2562236
10/11/18 12:54 AM
10/11/18 12:54 AM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
Thanks!
Re: 73 three on da tree clutch replacement [Re: 68Cbarge] #2588376
12/07/18 12:49 AM
12/07/18 12:49 AM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
Update....Getting mixed reviews on the type of clutch to use.
Diaphragm? or Borg N Beck.
I have to admit the Waygun is my only standard transmission Mopar I ever owned.All others in the fleet just "happen" to be automatics.
I will be using an RV cam (Summit K6900),cheap headers,800CFM Thermoquad carb,heavy car (4000 pounds) with 3.23 gears and 16 inch 27 inch tall tires.I do haul schtuff with the waygun and love to goose it from time to time.
Hey...with 3 on da tree and no radio I gotta entertain myself...
BTW NO I will NOT cut a hole in the floor for a Pistol Grip.
The Waygun is just way too cool and so much fun to drive!
So..Borg n Beck? or Diaphram??
Re: 73 three on da tree clutch replacement [Re: 68Cbarge] #2588379
12/07/18 12:53 AM
12/07/18 12:53 AM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
Re: 73 three on da tree clutch replacement [Re: 68Cbarge] #2588388
12/07/18 01:16 AM
12/07/18 01:16 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Looks like a pretty cool ride.
The Borg & Beck tends to be a more heavy duty clutch that a diaphragm. If you want a more heavy duty, the Borg & Beck is probably your best choice. Its likely there is a Borg & Beck in there now.
Diaphragm clutches have an easy pedal effort, so they tend to slip a little more when engaged. Gene
Re: 73 three on da tree clutch replacement [Re: 68Cbarge] #2588401
12/07/18 01:45 AM
12/07/18 01:45 AM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
Thanks!
Re: 73 three on da tree clutch replacement [Re: 68Cbarge] #2588499
12/07/18 11:08 AM
12/07/18 11:08 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
iagree with Gene.
Very cool wagon. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 73 three on da tree clutch replacement [Re: I_bleed_MOPAR] #2588562
12/07/18 01:35 PM
12/07/18 01:35 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I like the original style Borg & Beck. I don't find them heavy at all if it's a stock replacement style clutch. The over center spring helps a lot.
If you do go with a diaphragm clutch, you should remove the over center spring or make a pedal stop to keep the clutch from hanging up.
Re: 73 three on da tree clutch replacement [Re: 68Cbarge] #2591853
12/14/18 02:29 PM
12/14/18 02:29 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
Ordered a Hays Borg n Beck one up from stock up to 450 HP
The HP is not a concern,just a heavy car that hauls schtuff.
Will be installed in the spring after hibernation..
Re: 73 three on da tree clutch replacement [Re: 68Cbarge] #2592211
12/15/18 07:41 AM
12/15/18 07:41 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
What a neat ride!
Re: 73 three on da tree clutch replacement [Re: bobby66] #2592239
12/15/18 10:50 AM
12/15/18 10:50 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Originally Posted By bobby66
What a neat ride!
I agree!
