Page 2 of 3 1 2 3
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2561304
10/09/18 09:47 AM
10/09/18 09:47 AM
London, England
Gavin Offline
Gavin  Offline
London, England
If you really want one it's not hard to wind your own - people have even used coat hangers for this! Stainless wire is probably a better option. Find a suitable diameter cylinder as a former and manually wind the wire around it.
Although it's being referred to here as a spring, it is not performing the function of one, so does not need to be from spring steel etc.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2561324
10/09/18 10:58 AM
10/09/18 10:58 AM
BDW Online content
BDW  Online Content
I also got 1 from CJ Pony, cheap and easy and it works.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2561372
10/09/18 01:01 PM
10/09/18 01:01 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Same here BDW...
JOe
Re: Why did they stop with springs in lower rad hoses? [Re: BDW] #2561473
10/09/18 04:17 PM
10/09/18 04:17 PM
BlueRacer69 Offline
BlueRacer69  Offline
So did I. Around $7 bucks if I remember right.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2561707
10/10/18 12:35 AM
10/10/18 12:35 AM
5thAve Offline
5thAve  Offline
I've seen the springs at local parts stores to add to the lower hose. When I replace the hose I always swap the spring from the old hose to the new one.
Re: Why did they stop with springs in lower rad hoses? [Re: 5thAve] #2561947
10/10/18 02:58 PM
10/10/18 02:58 PM
be sure to turn the ends inward toward the center.
Re: Why did they stop with springs in lower rad hoses? [Re: RapidRobert] #2561965
10/10/18 03:26 PM
10/10/18 03:26 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Never needed one!! stirthepot
Re: Why did they stop with springs in lower rad hoses? [Re: 318 Stroker] #2562138
10/10/18 09:21 PM
10/10/18 09:21 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Originally Posted By 318 Stroker
Originally Posted By PLUM_72
So can one buy a replacement spring to put in a lower hose, if you wanted one?
I went to the local auto parts stores and bought a universal corrugated hose with a spring in it for 10.00. Pulled it and installed in my hose.
That's what I did when I pulled the old spring out and it was rusted as #$%^
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Why did they stop with springs in lower rad hoses? [Re: hemi-itis] #2562230
10/11/18 12:31 AM
10/11/18 12:31 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Is the small block one from CJ pony parts, what we need for a BB Mopar? I see a small and big block option.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2605419
01/12/19 03:13 PM
01/12/19 03:13 PM
Central Florida
larrymopar360 Online content OP
Stud Muffin
larrymopar360  Online Content OP
Stud Muffin
Central Florida
My brand new lower hose on my Power Powagon collapsed while idling in traffic on hot day here in Florida. First time I've had this happen. I noticed when temp gauge shot up and I popped hood and no leaks anywhere. New radiator, milodon water pump, thermostat....everthing is new in cooling system so I figured it might be that.
Also, I've noticed our Charger police cars have spring in upper hoses (reverse flow I guess?), so that kind of defeats the theory they were for factory fill purposes.
Facts are stubborn things.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2605423
01/12/19 03:18 PM
01/12/19 03:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Go back and think about what you just said.
Don't be the exception.
Re: Why did they stop with springs in lower rad hoses? [Re: Supercuda] #2605453
01/12/19 04:04 PM
01/12/19 04:04 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Not very helpful. If I missed something, excuse me! Can you just clear it up for me? Admittedly, I'm not a genius and might have missed something. But, I believe someone wrote they DON'T use springs anymore because they have a different method for factory fill, and that's what the springs were originally for, and NOT for eliminating collapsing hoses during consumer use.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2605456
01/12/19 04:09 PM
01/12/19 04:09 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
My Power Wagon runs very cool otherwise. Engine runs great, and it will cruise all day long on the highway at 70mph, and will run in traffic for hours no problem. But that one time on a very hot day, bam, temp shot up and the lower hose was sunk in.
I've done a ton of work on this engine. Just about everything but piston rings. It's had complete valve job, new cam and lifters, radiator, freeze plugs, timing chain, water pump, thermostat, hoses, belts, plugs, wires, ignition, timing set, headers, dual exhausts. It's squared away. I've since bypassed heater since core is at rad shop right now being repaired.
It did not overheat in traffic that time because of something else. I'm going to get a spring for lower hose (or wire if you want to be technical). Thank you to those with helpful answers.
Re: Why did they stop with springs in lower rad hoses? [Re: StukaJU87] #2605460
01/12/19 04:14 PM
01/12/19 04:14 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I ordered from CJ Pony Parts. Lower radiator hose spring stainless steel small block 1965-73. It was $8.99
https://www.cjponyparts.com/catalogsearc...l+block+1965-73
My truck is '79 with Max Cooling and HUGE lower hose.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2605463
01/12/19 04:19 PM
01/12/19 04:19 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Here’s my non-scientific pragmatic approach to it......
I’ve seen numerous vehicles through the years suffer from the “bottom hose sucked shut/engine runs hot” scenario........ where adding the “spring” fixed it.
It’s a cheap and easy thing to try........ if it doesn’t help, you’re not out much time or money.
If it does...... it was a simple cost effect solution.
If you’re having issues with the lower hose getting sucked shut..... it certainly can’t hurt anything to try adding the spring.
Re: Why did they stop with springs in lower rad hoses? [Re: fast68plymouth] #2605556
01/12/19 07:55 PM
01/12/19 07:55 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2605559
01/12/19 07:57 PM
01/12/19 07:57 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I agree ^
Going to try it.
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2605586
01/12/19 09:29 PM
01/12/19 09:29 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
You can also put a little tension into the hose when you install it to sort of "pre load" it. Just make sure you twist it opposite of the way the motor rocks when under load. I've had the same issue with some long top hoses that needed a little tweak.
Re: Why did they stop with springs in lower rad hoses? [Re: Montclaire] #2605601
01/12/19 10:15 PM
01/12/19 10:15 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Re: Why did they stop with springs in lower rad hoses? [Re: larrymopar360] #2605652
01/12/19 11:46 PM
01/12/19 11:46 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
No springs here and no problems either.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Page 2 of 3 1 2 3
