60 foot times #2561346
10/09/18 12:12 PM
10/09/18 12:12 PM
W.Va
fowl play Offline OP
W.Va
Mid ten second a body small block car, what are your 60 foot times. I'm at 1.47, think it should be faster Let know yours, I may have work to do for next year.
Re: 60 foot times [Re: fowl play] #2561360
10/09/18 12:34 PM
10/09/18 12:34 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My best is a 1.41 on a 10.54@124.6. 3500lb small block a body barracuda.
4800 8" TA
904
4.10 rear
28" pro bracket radial.
416"
68 Barracuda Formula S 340
Re: 60 foot times [Re: fowl play] #2561407
10/09/18 01:58 PM
10/09/18 01:58 PM
UK
rb446 Offline
rb446  Offline
UK
A 3300lb A- bod shows up as>
60 Foot E.T. : 1.47
1/8 Mile E.T. : 6.68
1/8 Mile Trap Speed : 101.78
1/4 Mile E.T. : 10.58
1/4 Mile Trap Speed : 127
1/4 Mile Trap RPM : 0
__________
60 Foot E.T. : 1.46
1/8 Mile E.T. : 6.64
1/8 Mile Trap Speed : 102.39
1/4 Mile E.T. : 10.52
it can be bettered and normally are slightly as these are parameters for average>good hook cars.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: 60 foot times [Re: rb446] #2561417
10/09/18 02:07 PM
10/09/18 02:07 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My Sons Matt's 360. Right side.
Untitled by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 60 foot times [Re: fowl play] #2561493
10/09/18 05:14 PM
10/09/18 05:14 PM
Gravataí, RS, Brazil
360tripleblack77 Offline
Small Block 360", Pump gas, Eddy Heads, Tunnel Ram, OEM Leaf Springs, 3300lbs...
1.50 60'
4.31 330'
6.73@102.54mph
I've changed from OEM leaf spring to Calvert Monoleafs. Should drop my 60ft I hope.
My goal is run at 6.5 that should run 10.5 at 1/4mile.
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: 60 foot times [Re: fowl play] #2561762
10/10/18 02:46 AM
10/10/18 02:46 AM
Washington
skrews Offline
skrews  Offline
Washington
3300# duster
365 11.75
252° .528 SFT
904 5800vert footbrake
4.56 28x10.5
Caltracs
Re: 60 foot times [Re: fowl play] #2561824
10/10/18 10:48 AM
10/10/18 10:48 AM
UK
rb446 Offline
rb446  Offline
UK
And here's a ticket from 1991...bad 60>
3300lb...440, ladders/coils, 4.88's/32" tyre, 4800 stall
[img:center][/img]
Re: 60 foot times [Re: fowl play] #2561907
10/10/18 01:24 PM
10/10/18 01:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It's interesting to look at the 60's in this post. Compare with the 330's. 60ft varience can be do to power, gear, converter. All without ever being affected by chassis/suspension/tire spin.
Doug
Re: 60 foot times [Re: fowl play] #2561932
10/10/18 02:18 PM
10/10/18 02:18 PM
Locomotion Offline
Locomotion  Offline
Best 60' times are achieved through careful coordination of the whole package, including carb. accelerator pump tuning, converter, gearing, suspension and everything else mentioned.
I've gotten 1.47 60' times while running only low 11-teens (117 mph)/high 6.90's in a 3,540+ lb 360/904/4.86 gear footbrake Dart on 9" tires & SS type springs. (I'm at work and don't have my log info handy.) But there are other similar Stock class type care that 60' even better with similar ET/MPH. It takes lots of testing, tuning and often trying a lot of various parts.
Not to discourage their use, but I know of one racer who swapped from SS style leaf springs to Cal-Tracs and he didn't gain anything. But he likely had his suspension working as efficiently as possible already, which isn't easy. The Cal-Tracs do have much more adjustability than SS springs. The change did save some weight also and it was redistributed in the car for maximum benefit.
