Re: 60 foot times
[Re: fowl play]
#2561360
10/09/18 12:34 PM
10/09/18 12:34 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
My best is a 1.41 on a 10.54@124.6. 3500lb small block a body barracuda.
4800 8" TA 904 4.10 rear 28" pro bracket radial. 416"
68 Barracuda Formula S 340
Re: 60 foot times
[Re: fowl play]
#2561407
10/09/18 01:58 PM
10/09/18 01:58 PM
Posts: 570 UK
rb446
UK
A 3300lb A- bod shows up as> 60 Foot E.T. : 1.47 1/8 Mile E.T. : 6.68 1/8 Mile Trap Speed : 101.78 1/4 Mile E.T. : 10.58 1/4 Mile Trap Speed : 127 1/4 Mile Trap RPM : 0 __________ 60 Foot E.T. : 1.46 1/8 Mile E.T. : 6.64 1/8 Mile Trap Speed : 102.39 1/4 Mile E.T. : 10.52 1/4 Mile Trap Speed : 127 1/4 Mile Trap RPM : 0 it can be bettered and normally are slightly as these are parameters for average>good hook cars.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
Re: 60 foot times
[Re: rb446]
#2561417
10/09/18 02:07 PM
10/09/18 02:07 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My Sons Matt's 360. Right side. Untitled by John Cadamore, on Flickr
Re: 60 foot times
[Re: fowl play]
#2561493
10/09/18 05:14 PM
10/09/18 05:14 PM
Posts: 192 Gravataí, RS, Brazil
360tripleblack77
Small Block 360", Pump gas, Eddy Heads, Tunnel Ram, OEM Leaf Springs, 3300lbs...
1.50 60' 4.31 330' 6.73@102.54mph
I've changed from OEM leaf spring to Calvert Monoleafs. Should drop my 60ft I hope.
My goal is run at 6.5 that should run 10.5 at 1/4mile.
'77 Brazilian Dodge Charger R/T - Street Car Footbrake, Pump Gas, SB Mopar 360" N/A 3300lbs, Leaf Spring + Assassin Bars Best 1/8 mile ET 1.50 60' / 4.31 330' / 6.73@102.54mph
Re: 60 foot times
[Re: fowl play]
#2561762
10/10/18 02:46 AM
10/10/18 02:46 AM
Posts: 429 Washington
skrews
Washington
3300# duster 365 11.75 252° .528 SFT 904 5800vert footbrake 4.56 28x10.5 Caltracs
Re: 60 foot times
[Re: fowl play]
#2561824
10/10/18 10:48 AM
10/10/18 10:48 AM
Posts: 570 UK
rb446
UK
And here's a ticket from 1991...bad 60> 3300lb...440, ladders/coils, 4.88's/32" tyre, 4800 stall [img:center] [/img]
Re: 60 foot times
[Re: fowl play]
#2561932
10/10/18 02:18 PM
10/10/18 02:18 PM
Posts: 5,894 Florida
Locomotion
Best 60' times are achieved through careful coordination of the whole package, including carb. accelerator pump tuning, converter, gearing, suspension and everything else mentioned.
I've gotten 1.47 60' times while running only low 11-teens (117 mph)/high 6.90's in a 3,540+ lb 360/904/4.86 gear footbrake Dart on 9" tires & SS type springs. (I'm at work and don't have my log info handy.) But there are other similar Stock class type care that 60' even better with similar ET/MPH. It takes lots of testing, tuning and often trying a lot of various parts.
Not to discourage their use, but I know of one racer who swapped from SS style leaf springs to Cal-Tracs and he didn't gain anything. But he likely had his suspension working as efficiently as possible already, which isn't easy. The Cal-Tracs do have much more adjustability than SS springs. The change did save some weight also and it was redistributed in the car for maximum benefit.
