Page 4 of 6 1 2 3 4 5 6
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2556432
09/29/18 10:40 PM
09/29/18 10:40 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Did it make 771 on pump 93 or 100 race gas?
Re: 771 horse stock stroke 360 motor, pump gas [Re: justinp61] #2556513
09/30/18 01:41 AM
09/30/18 01:41 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Dont know.
No matter the case, hell of an achievment by the builder. And like he said, it makes over 800 if he runs it 8,000.
The contest is from 4 to 7500 rpm. Certain limitations cause it was built to suit the rules.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2556528
09/30/18 03:11 AM
09/30/18 03:11 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Stock block, stock stroke SB making 800ish is awesome. Who cares if it's on 91, 100, or 116?
There's a station by me that has 100 Cam 2 at the pump, so it's pump gas to me. boogie
Re: 771 horse stock stroke 360 motor, pump gas [Re: slantzilla] #2556529
09/30/18 03:19 AM
09/30/18 03:19 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I know a guy that has a pump on his nitromethane. Lol.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 771 horse stock stroke 360 motor, pump gas [Re: CMcAllister] #2556542
09/30/18 09:07 AM
09/30/18 09:07 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Originally Posted By CMcAllister
Use studs, add bolts, whatever. When what you are bolting it to is flimsy, the benefit is limited. When the mating surfaces are fretted, the caps are dancing around.
While i do agree,i also believe a whole lot of times the main isue with maincaps tapdancing in the block comes from detonation and not neccesarily from just to much power,same with most smallblocks that end up pushing a headgasket,sure the 4headbolts per cylinder may not be genius when making big power but the limit for how much compression you can run before pushing a headgasket gets much lower if you also have a problem with detonation,and detonation that starts creating isues is present long before we hear it and it gets catastrophic as in destroyed pistons.
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2556554
09/30/18 10:17 AM
09/30/18 10:17 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Dont know.
I agree.
Re: 771 horse stock stroke 360 motor, pump gas [Re: 1Fast340] #2556964
10/01/18 12:09 PM
10/01/18 12:09 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I 100% agree... if you keep them out of detonation they'll take a lot more power then people give them credit for.
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2556967
10/01/18 12:19 PM
10/01/18 12:19 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
We’ll all find out how it compares in a few days.
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2556969
10/01/18 12:25 PM
10/01/18 12:25 PM
P
Porter67 Offline
Porter67  Offline
P
I wonder what the bobweight is? Im sure the less the stock stroke helps as well.
I didnt read it all, but I wonder if they got a test mule car lined up for it after the competition.
I re read it all and not mention of tq numbers?
I wonder what the top end would do on a big inch stroker?
It is interesting and impressive, not sure how down to earth the .100 over and 3/4 filled oem block is for lifespan.
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2556986
10/01/18 01:02 PM
10/01/18 01:02 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Think his scheduled dyno time is 11 in the morning on Thursday.
They head down to Charlotte tomorrow
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2557009
10/01/18 01:42 PM
10/01/18 01:42 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Don't disagree on the detonation. But. Flat tops - 11.5:1 static compression, C12, run fat enough to color the plugs, 36* timing, 140-150 degrees, old (mild) roller cam, not burning oil, filled to the water pump holes, everything studded...and the caps were dancing.
Re: 771 horse stock stroke 360 motor, pump gas [Re: HotRodDave] #2557057
10/01/18 02:52 PM
10/01/18 02:52 PM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
Originally Posted By HotRodDave
I been saying it for years... a magnum block has more meat where it is needed and is at least harder if not stronger iron as well as more consistant castings. I even posted pictures and nobody seems to care, now I cant post pics anymore so you would have to look back a couple years in my old posts.
I agree. I went magnum and never looked back.
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2557119
10/01/18 04:41 PM
10/01/18 04:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I think a lot of guys miss the point of the competetion, it is a contest for engine builders that eliminates the variability of a car, track, driver, all that stuff just to see who knows how to make the most power.
Another way to do it would be use one car and swap everyones engine in it over the course of a few days but conditions could change a lot over the course of a day so even that might not be fair so the dyno competetion seems the best way to compare engine builders to engine builders.
You could also have another contest for car builders, use say 10 of the exact same engines and have car builders build a car to see who can make the fastest car with the same engine.
The engine masters contest is to have a competetion between engine builders plain and simple. Who can make the most power witin given parameters. It compares one aspect of what makes good cars. If you want to see how entire cars compare then go to a race track any weekend and watch em. All the belly aching about "well I dont think thats going to be fast in a real car" is pointless, totally misses the point of the contest. I dont get why thats so hard to comprehend.
Re: 771 horse stock stroke 360 motor, pump gas [Re: HotRodDave] #2557124
10/01/18 04:47 PM
10/01/18 04:47 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
You totally get it man. Kudo’s to ya.
I watch people snipe people at people’s accomlishments that do really cool things in our hobby.
Guaranteee this motor would scream in a typical A body
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2557144
10/01/18 05:42 PM
10/01/18 05:42 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice motor...thanks for sharing Don.
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2557182
10/01/18 07:00 PM
10/01/18 07:00 PM
P
Porter67 Offline
Porter67  Offline
P
Im seeing some mixed messages here, look at the posts about the one or two engine masters motors that went on to have a service life in a track car.
So why not put this one in the mix for consideration?
I think its all cool as hell and even better its not our cash and we still get 85% of the thrill factor talking about it and watching what will come.
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2557863
10/02/18 07:00 PM
10/02/18 07:00 PM
Washington
madscientist Offline
Washington
So is this one of those deals that's going to be on the web?
If so, how do you watch the thing? Is there a link? Do I have to download a bunch of crap or what?
Thanks in advance.
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2557909
10/02/18 08:00 PM
10/02/18 08:00 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Gonna call tomorrow and hopefully find out. Pulls are Thursday
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 771 horse stock stroke 360 motor, pump gas [Re: B3422W5] #2557919
10/02/18 08:24 PM
10/02/18 08:24 PM
Washington
Washington
Thanks. I'd love to watch it if I can.
Re: 771 horse stock stroke 360 motor, pump gas [Re: madscientist] #2558203
10/03/18 12:37 PM
10/03/18 12:37 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Unfortunately wont be any live streaming.
Results will be posted on speedtalk in general discussion.
Just got an email back from them.......
1.41 best 60 foot
6.60 at 103.90 1/8
