Which "forum" do i use for questions on fuel-injection syst. #2556841
10/01/18 12:35 AM
10/01/18 12:35 AM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
I might be starting to look at FiTech or Holley FI systems for a 340. i'd like to ask questions of people who took off their carbs and bolted on one of these systems. Which forum should I look at? Thanks
Still looking for LM29H1B415501, '71 Demon 340
Re: Which "forum" do i use for questions on fuel-injection syst. [Re: PAULS_340] #2556902
10/01/18 09:08 AM
10/01/18 09:08 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Probably here, many have done it.
I have used a fitech, but not a holley.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Which "forum" do i use for questions on fuel-injection syst. [Re: PAULS_340] #2556916
10/01/18 10:36 AM
10/01/18 10:36 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
You might also go to Yellowbullet and do a search there. You'll find a lot more posts on this subject although not specific to Mopars.
Master, again and still
Re: Which "forum" do i use for questions on fuel-injection syst. [Re: PAULS_340] #2556961
10/01/18 12:06 PM
10/01/18 12:06 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Really should have its own forum, but the "its got electrolytes" still carries a lot sway. laugh2
Re: Which "forum" do i use for questions on fuel-injection syst. [Re: PAULS_340] #2556995
10/01/18 01:17 PM
10/01/18 01:17 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Both Holley and FiTech have faceBook Groups:
https://www.facebook.com/groups/SniperEFISupport/
https://www.facebook.com/groups/1138882606178838/
You can search and ask here also.
There is a bit of a learning curve to EFI, but the Sniper and FiTech are pretty easy to install and setup.
If the engine has issues like intake or exhaust leaks it will really mess with the self-learning EFI. Also need a good EFI fuel system that is filtered well. In-tank pump works well and makes install a bit easier because there are less connections to make. Make sure to flush the fuel lines before connecting them.
Re: Which "forum" do i use for questions on fuel-injection syst. [Re: PAULS_340] #2558126
10/03/18 10:06 AM
10/03/18 10:06 AM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
Re: Which "forum" do i use for questions on fuel-injection syst. [Re: PAULS_340] #2558636
10/03/18 10:39 PM
10/03/18 10:39 PM
BDW Offline
BDW  Offline
I have Fitech and wish there was a useful forum.
I've tried the FB group but it's just not set up for getting info and not user friendly.
Re: Which "forum" do i use for questions on fuel-injection syst. [Re: BDW] #2558658
10/03/18 11:30 PM
10/03/18 11:30 PM
Motown, Mi
P
P
Motown, Mi
So this turns out to be a pretty good question by the replies. What I actually meant was, which forum on this website. Maybe we need a new one? Thanks for the feedback.
Re: Which "forum" do i use for questions on fuel-injection syst. [Re: PAULS_340] #2558743
10/04/18 03:34 AM
10/04/18 03:34 AM
Guitar Jones Offline
If it were me I would post questions in the race forum.
Re: Which "forum" do i use for questions on fuel-injection syst. [Re: PAULS_340] #2561277
10/09/18 04:17 AM
10/09/18 04:17 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I can help. Call me.
