transmission adapter #255547
03/16/09 11:15 AM
03/16/09 11:15 AM
ohio
dodgedart416 Offline OP
ohio
anyone make mopar small block to mopar big block trans adapter?
Re: transmission adapter [Re: dodgedart416] #255548
03/16/09 11:23 AM
03/16/09 11:23 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: transmission adapter [Re: WILD BILL] #255549
03/16/09 12:50 PM
03/16/09 12:50 PM
NY usa
540challenger Offline
NY usa
it might be cheaper to just find a big block case or core and swap the guts out.
Re: transmission adapter [Re: 540challenger] #255550
03/16/09 01:17 PM
03/16/09 01:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That would be too simple , unless he is trying to adapt an OD trans ?
Re: transmission adapter [Re: JohnRR] #255551
03/16/09 01:57 PM
03/16/09 01:57 PM
ohio
ohio
I am trying to adapt to od trans it is stock motor. Will ultra bell fit od trans?
Re: transmission adapter [Re: dodgedart416] #255552
03/16/09 01:59 PM
03/16/09 01:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes , you cut off the current bellhousing of the trans and it bolts on to the front pump
Re: transmission adapter [Re: JohnRR] #255553
03/16/09 02:02 PM
03/16/09 02:02 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Plus, its 600 times stronger than the stock bellhousing.
Re: transmission adapter [Re: dodgedart416] #255554
03/16/09 02:13 PM
03/16/09 02:13 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
JVX in Tenesee has had an adapter available since the early '90's.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: transmission adapter [Re: racealittle] #255555
03/16/09 06:22 PM
03/16/09 06:22 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Ultra bell
Moparlee
Re: transmission adapter [Re: Robbins] #255556
03/16/09 06:23 PM
03/16/09 06:23 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
2
Moparlee
Re: transmission adapter [Re: Robbins] #255557
03/16/09 06:24 PM
03/16/09 06:24 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Going behind this
Moparlee
Re: transmission adapter [Re: Robbins] #255558
03/16/09 07:55 PM
03/16/09 07:55 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Pat has an adapter kit
http://www.smrtrans.com/
