Re: transmission adapter
[Re: 540challenger]
#255550
03/16/09 01:17 PM
03/16/09 01:17 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
it might be cheaper to just find a big block case or core and swap the guts out.
That would be too simple , unless he is trying to adapt an OD trans ?
[Re: dodgedart416]
#255552
03/16/09 01:59 PM
03/16/09 01:59 PM
JohnRR
U.S.S.A.
I am trying to adapt to od trans it is stock motor. Will ultra bell fit od trans?
Yes , you cut off the current bellhousing of the trans and it bolts on to the front pump
[Re: JohnRR]
#255553
03/16/09 02:02 PM
03/16/09 02:02 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Plus, its 600 times stronger than the stock bellhousing.
[Re: dodgedart416]
#255554
03/16/09 02:13 PM
03/16/09 02:13 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
JVX in Tenesee has had an adapter available since the early '90's.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
