Anyone ever have this happen to their alternator? #2555111
09/26/18 05:25 PM
09/26/18 05:25 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I hadn't started my Duster in a few weeks so I went out in the garage today to do so. I started it up and suddenly heard a strange noise I never heard before. It was kind of a whirring/buzzing sound when I revved the motor. When it returned to idle speed the sound stopped. Did this a couple of times so I shut it off and looked under the hood. To my surprise this is what I found. Wasn't like that before so I don't know what happened. The motor is just a stock 318.
Re: Anyone ever have this happen to their alternator? [Re: 1970RT] #2555114
09/26/18 05:41 PM
09/26/18 05:41 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
How did you tighten the belt the last time?
Re: Anyone ever have this happen to their alternator? [Re: 1970RT] #2555120
09/26/18 05:55 PM
09/26/18 05:55 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Yea, It looks like it was probably pryed on when tightening ( maybe not by you but maybe PO)and the crack started. Then over time the crack got larger.
Re: Anyone ever have this happen to their alternator? [Re: mopars4ever] #2555122
09/26/18 06:01 PM
09/26/18 06:01 PM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
Another possibility is the thickness or stackup of the spacers are incorrect and basically when it was tightened down it wanted to try and pull the ears of the alternator together.
Re: Anyone ever have this happen to their alternator? [Re: 1970RT] #2555126
09/26/18 06:18 PM
09/26/18 06:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Why is everything silver?
Don't be the exception.
Re: Anyone ever have this happen to their alternator? [Re: Supercuda] #2555173
09/26/18 07:55 PM
09/26/18 07:55 PM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
because... its Purdy like that.. eek ... I wonder if it effects the alternator output or not?
Re: Anyone ever have this happen to their alternator? [Re: 1970RT] #2555178
09/26/18 08:02 PM
09/26/18 08:02 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It appears that the belt/pulley is out of alignment? That and some metal fatigue from prying on it to adjust it probably did it in.
Re: Anyone ever have this happen to their alternator? [Re: ngpSatellite] #2555187
09/26/18 08:32 PM
09/26/18 08:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I was wondering if it was affected by it too.
As for the belt alignment, a laser bore sight tool laid in the pulley groove will self center in that pulley and you can check alignment with it very accurately.
Re: Anyone ever have this happen to their alternator? [Re: 1970RT] #2555202
09/26/18 09:00 PM
09/26/18 09:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If the rear mounting ear breaks then yes, it throws the pulley out of alignment.
It would have to be set back up with an intact alternator to know if the alignment was off before this happened.
Re: Anyone ever have this happen to their alternator? [Re: 1970RT] #2555279
09/26/18 11:07 PM
09/26/18 11:07 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Thats a new one to me.
When you take it off, examine the fracture.
At minimum you will see if the any or all of the fracture is fresh or old. Heck. Someone could have dropped it on a concrete floor and started a fracture then.
Re: Anyone ever have this happen to their alternator? [Re: 1970RT] #2555302
09/26/18 11:40 PM
09/26/18 11:40 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I'm betting the belt alignment was off causing the case to break. In the one picture, that belt is coming at a pretty hard angle towards the alt pulley. Even with the case broken, the outer edge of the pulley still isn't in line with the belt. It looks like the alt would have needed an outer pulley to be inline with the water pump pulley.
It looks like maybe the front ear of the alt needs sit outside of the bracket coming from the water pump, then you might need a different rear spacer. You may have incorrect brackets. Gene
Re: Anyone ever have this happen to their alternator? [Re: chargerbr549] #2555312
09/27/18 12:01 AM
09/27/18 12:01 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Yep seen this many a time.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Anyone ever have this happen to their alternator? [Re: moparmarks] #2555362
09/27/18 01:59 AM
09/27/18 01:59 AM
^^^ X3
Re: Anyone ever have this happen to their alternator? [Re: 1970RT] #2555368
09/27/18 02:26 AM
09/27/18 02:26 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Yes look how far the rear sliding section is pushed in....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Anyone ever have this happen to their alternator? [Re: HemiRick] #2555370
09/27/18 02:39 AM
09/27/18 02:39 AM
Las Vegas, NV
Las Vegas, NV
The alternator bracket should be sandwiched with the long spacer in between the two ears not out in the front. Here is a link to a pic of a small block setup.
https://www.forbbodiesonly.com/moparforum/attachments/altstock-jpg.12272/
Re: Anyone ever have this happen to their alternator? [Re: chargerbr549] #2555389
09/27/18 04:04 AM
09/27/18 04:04 AM
that inner "split" sleeve needs to be protruding a bit behind the rear ear (cant see in the pic) & the right length long spacer "inbetween" the ears with just the right length (add washers if needed) so the ears ain't being pressed "inward" & the inner split sleeve(s) are taking the compression. EDIT I looked at the pic again & the rear split sleeve might need to pressed rear ward a bit (so some of it protrudes rearward from the rear ear), "as/if needed" cuz some needs to be protruding, then slightly shorten the rear spacer to maintain the alt/pulley alignment.
Re: Anyone ever have this happen to their alternator? [Re: 1970RT] #2555417
09/27/18 09:28 AM
09/27/18 09:28 AM
own private Idaho
N
N
own private Idaho
Also .. when you get a new one ... get one with the stator not painted / coated with that paint. not sure but you could be creating more heat as well thus in the long run weakening your metal case... get one that has that nice shiny copper with no paint...
Re: Anyone ever have this happen to their alternator? [Re: ngpSatellite] #2555512
09/27/18 01:01 PM
09/27/18 01:01 PM
moparx Online content
moparx  Online Content
saw that a lot in my days as a junkyard owner. two causes for that to happen, both previously mentioned. using a big prybar to set belt tension, and mixing up, or not using the correct spacers. happened on all brands, so not mopar specific.
beer
Re: Anyone ever have this happen to their alternator? [Re: 1970RT] #2555727
09/27/18 10:14 PM
09/27/18 10:14 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
As mentioned earlier, looks like the upper alternator bracket is not positioned properly. The bracket should be between the outer alternator ear and the spacer. The split sleeve is pushed forward because the bracket isn't in the right place.
When you work on Spaceships for a living, how bad can a workday be?
