Re: Anyone ever have this happen to their alternator?
[Re: 1970RT]
#2555126
09/26/18 06:18 PM
09/26/18 06:18 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Why is everything silver?
[Re: Supercuda]
#2555173
09/26/18 07:55 PM
09/26/18 07:55 PM
Posts: 936 own private Idaho
ngpSatellite
own private Idaho
because... its Purdy like that.. ... I wonder if it effects the alternator output or not?
[Re: ngpSatellite]
#2555187
09/26/18 08:32 PM
09/26/18 08:32 PM
Supercuda
About to go away
About to go away
up yours
because... its Purdy like that.. ... I wonder if it effects the alternator output or not? I was wondering if it was affected by it too. As for the belt alignment, a laser bore sight tool laid in the pulley groove will self center in that pulley and you can check alignment with it very accurately.
[Re: chargerbr549]
#2555312
09/27/18 12:01 AM
09/27/18 12:01 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Another possibility is the thickness or stackup of the spacers are incorrect and basically when it was tightened down it wanted to try and pull the ears of the alternator together. Yep seen this many a time.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: 1970RT]
#2555368
09/27/18 02:26 AM
09/27/18 02:26 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Yes look how far the rear sliding section is pushed in....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: chargerbr549]
#2555389
09/27/18 04:04 AM
09/27/18 04:04 AM
RapidRobert
that inner "split" sleeve needs to be protruding a bit behind the rear ear (cant see in the pic) & the right length long spacer "inbetween" the ears with just the right length (add washers if needed) so the ears ain't being pressed "inward" & the inner split sleeve(s) are taking the compression. EDIT I looked at the pic again & the rear split sleeve might need to pressed rear ward a bit (so some of it protrudes rearward from the rear ear), "as/if needed" cuz some needs to be protruding, then slightly shorten the rear spacer to maintain the alt/pulley alignment.
[Re: 1970RT]
#2555727
09/27/18 10:14 PM
09/27/18 10:14 PM
Posts: 406 California City, CA
dart440
California City, CA
As mentioned earlier, looks like the upper alternator bracket is not positioned properly. The bracket should be between the outer alternator ear and the spacer. The split sleeve is pushed forward because the bracket isn't in the right place.
When you work on Spaceships for a living, how bad can a workday be?
