ET on a low-budget 440 A Body?
#2554934
09/26/18 10:30 AM
09/26/18 10:30 AM
Posts: 910 Southern Oregon
toyotajeep
Southern Oregon
Hello,
Years ago I built a 440 Dart Sport with my students. Sold it too quickly. I decided to do it again, bought a bunch of stuff and then changed my mind. Tried to sell it.
I have a lot of low-end Mopar stuff now and can't give it away. Thinking of using it. Here is what I have on hand.
67 Valiant, cut for fender wells. Decent body lacking interior etc. $800 car more or less. Have mounts for 440. Think "patina'd" cruiser. Likely going to mini-tub it etc.
Engine is a 440 from 76, NIB single bolt timing set. Holley SD Intake. 750 Holley that is new. Good quality electric pump and reg. Engine is stock, willing to cam it, port heads etc. Not wanting to rebuild, good re-ring candidate.
727. Access to a good quality 3500 RPM stall if I want it.
Spring relocation kit.
8.75 or 8.8 I can narrow myself. 8.8 has 3.73 gears.
Fenderwell headers that are 1.875, not Hookers. Willing to run 3" or whatever exhaust.
If you were on a budget, and just wanted to go fast but still be streetable what do you think I can run for the ET?
Cam recommendations? This would be a once a week to work car, and a trip down the strip.
1989 Dodge Cummins & 1989 Dodge W-250
Re: ET on a low-budget 440 A Body?
[Re: toyotajeep]
#2554950
09/26/18 11:15 AM
09/26/18 11:15 AM
Posts: 4,684 Wichita
GY3
Wichita
280° advertised duration and.480-ish lift would be my recommendation for a cam. Sounds like the car is pretty light, so mid twelves should pretty easy.
[Re: toyotajeep]
#2555168
09/26/18 07:46 PM
09/26/18 07:46 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I did this build in 1983, no money, 67 Valiant, 440, Hemi cam, Hooker fenderwells, mild converter, 4.10s in a 8 3/4, I don't know how fast it was because it never got to the track but that was a fun car!!!
Have a great day Iowan
"obsolete is neat"
[Re: toyotajeep]
#2555186
09/26/18 08:30 PM
09/26/18 08:30 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
For the heads, decent flow can be had by going to 2.14 intake and 1.81 exhaust valves, and a bowl port. If you are willing to consider some cast replacement pistons ,if available same weight as stock but with more compression, that would really help. I am not sure what is available, just suggesting what i would check on to see if i could get by with just an overbore and rings to get compression up to a decent level.
[Re: gregsdart]
#2555280
09/26/18 11:08 PM
09/26/18 11:08 PM
toyotajeep
Southern Oregon
Thank you for the help! I am quite able to make things etc. so we are going to cut weight etc. by removing some extras and that kinda thing. Of course by the time you tie the frame etc. you're really not saving much weight.
I want super simple and EZ to fix kinda car that is fun, and that can be used and worked on without concern. Really would like 12's in any weather condition.
Really going to have to keep the engine simple with springs, home porting and a cam etc. I know there is so much left on the table, but it is just going to have to be more simple for right now.
More likely than not, I would buy some aluminum heads next year and up the compression and start that, but for now this will need to work.
[Re: toyotajeep]
#2555339
09/27/18 12:55 AM
09/27/18 12:55 AM
gregsdart
Some years ago i did someback yard butchery on a low compression 340 for my son when neither of us had 2 cents to spend. I cleaned up the bowls with a die grinder, then back cut the stock valves by chucking them in a drill press and hitting them carefully with an angle grinder. We added headers, a 268h cam, and a TQ carb and that 340 performed very well!
[Re: toyotajeep]
#2555466
09/27/18 11:29 AM
09/27/18 11:29 AM
Posts: 570 UK
rb446
UK
Cool build, read it many times before, if you could follow that and get 400hp on track, thats enough with a good hook to run high 11's with exhaust in a...3200lb? all in car,..and your 3.73 gears with say 28" tyres would have you trapping@around 5300>5400rpm.. about right.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: toyotajeep]
#2555468
09/27/18 11:31 AM
09/27/18 11:31 AM
toyotajeep
Southern Oregon
One more question.
The convertor I have access to is a 10" Dynamic 3500 RPM rated convertor.
More convertor than I need most likely!
For the combo mentioned above, approximately what ET loss will likely occur with a stock convertor vs. the Dynamic?
It's from a buddy and pretty inexpensive so I will likely run it.
Cam specs are going to be 230 at .050 neighborhood.
[Re: toyotajeep]
#2555478
09/27/18 11:47 AM
09/27/18 11:47 AM
Posts: 570 UK
rb446
UK
The smallest converter I ever ran was a 3500 in my 340 with a 284/484 purple and that worked really well, so not the best on that. I would however hazard a guess of at least .3>.5 loss with a stock verter and a .230@.50 cam. Sure others will have a better idea with more experience than me.
[Re: rb446]
#2555487
09/27/18 12:02 PM
09/27/18 12:02 PM
Posts: 34,927 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Friend has a 73 Duster at our local track, track champ like 9-10 times
Low buck car , it does not have one trick part on it
451 , ported by himself 906 heads .. 727 , Dana
runs 10.70's in bad air
10.50's in good air
He has 1000's of runs on it , never lays a wrench on it
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: toyotajeep]
#2555503
09/27/18 12:20 PM
09/27/18 12:20 PM
toyotajeep
Southern Oregon
This is as much a process project as anything. My current students are awesome and enthusiastic, but have almost zero experience with a wrench. I am making up my mind on which car to do here in about a month.
I have a newer performance car and it is a lot of fun, but I'd like to go faster for sure.
For those of us older types, we grew up with N50's sticking out the back and airshocks (a little before my time but....) etc.
To a modern teenager, that stuff is incomprehensible. I want them to learn some basics, have fun and above all learn something valuable.
Many on here are older, and there is a strong shortage of young people still doing this stuff.
Lots of enthusiasm, now we just need to find the right target to aim at.
[Re: toyotajeep]
#2555630
09/27/18 06:01 PM
09/27/18 06:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you can you should build the lightest car you can.. there is 2 factors you will always be playing with.. HP and WEIGHT.. your not starting with a bunch of HP so you want to make the car as light as possible.. the easiest way is find the lightest car you can.. then take the weight out of it.. push thoughs 2 factors on the students and they they will get the big picture
[Re: cudadoug]
#2555692
09/27/18 09:03 PM
09/27/18 09:03 PM
toyotajeep
Southern Oregon
Wow! You didn't port and mill the heads? That is alot of ET for not much work all things considered. You had substantially more compression than I will for sure.
I hear you on the weight. I am going to trim where I can and remove things like the back seat, battery in trunk etc. Typical stuff.
[Re: toyotajeep]
#2555696
09/27/18 09:16 PM
09/27/18 09:16 PM
Posts: 4,209 New York
polyspheric
New York
240 @ .050", 108 LSA installed 104
Boffin Emeritus
