Re: Stubborn pitman arm removal
[Re: 440mopar]
#2552895
09/21/18 03:23 PM
09/21/18 03:23 PM
Posts: 1,820 South Bend
John Brown
South Bend
Fire. You only need to heat the arm in one spot. It will grow enough to loosen its grip on the shaft.
[Re: 440mopar]
#2552931
09/21/18 04:36 PM
09/21/18 04:36 PM
Challenger 1
Cincinnati, Ohio
What kind of puller are you using? Like said even with a bullet proof puller heat is required most times...IMO. Here is the most inexpensive way to get heat to use on stuff like this.
[Re: 440mopar]
#2553090
09/21/18 11:10 PM
09/21/18 11:10 PM
Posts: 20,631 in a cattle trailer down by th...
Guitar Jones
Have you tried harsh language?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: 440mopar]
#2553094
09/21/18 11:13 PM
09/21/18 11:13 PM
Guitar Jones
Seriously though, without having the box secured to something you aren't able to shock it with hammer blows. All the impact force is just going to move the box. It needs to be immobile.
[Re: 440mopar]
#2553555
09/23/18 11:09 AM
09/23/18 11:09 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
"There are very few personal problems that cannot be solved through a suitable application of high explosives." - Scott Adams A GOOD puller and a BFH, as already noted, should do it though. If you need heat I recommend a real acetylene torch. That little Bernz-O-Matic setup does work well on small objects but those expensive oxygen cylinders only last about ten minutes... I've got one and got tired of buying $10 bottles.
[Re: DrCharles]
#2553603
09/23/18 01:16 PM
09/23/18 01:16 PM
Challenger 1
Cincinnati, Ohio
"There are very few personal problems that cannot be solved through a suitable application of high explosives." - Scott Adams A GOOD puller and a BFH, as already noted, should do it though. If you need heat I recommend a real acetylene torch. That little Bernz-O-Matic setup does work well on small objects but those expensive oxygen cylinders only last about ten minutes... I've got one and got tired of buying $10 bottles. Yes and no as far as cost. Depends on how much you use it. I had a acetylene oxygen welding/cutting torch for 20 years at home on a cart. I ran out of space for it and got tired of paying for those tanks every year from the gas supplier. Plus I really didn't use it that often after I got a plasma cutter. So I got them out of my small garage. I still have a gas torch at work I use when I need one. I said it was the cheapest and all that is needed. Don't need a big ole torch for this job.
[Re: 440mopar]
#2553828
09/23/18 08:56 PM
09/23/18 08:56 PM
DrCharles
West Plains, MO
I ran out of space for it and got tired of paying for those tanks every year from the gas supplier. Plus I really didn't use it that often after I got a plasma cutter. I bought used tanks at a flea market, and when I need more gas I just turn them in at the local supplier and they give me a (used) full one. No monthly fees Speaking of cost, how much was your plasma cutter I've always wanted one but a good one isn't that cheap, and a cheap one isn't good.
[Re: 440mopar]
#2554098
09/24/18 02:51 PM
09/24/18 02:51 PM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Got my pitman arm off with the help of this thread. Thanks.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
