Casting 2468339? #2548550
09/10/18 10:36 PM
09/10/18 10:36 PM
Texas
TheHemi Offline OP
TheHemi  Offline OP
Texas
Is 2468339 a HEMI casting number?
I have 2468330 listed for the 426.
Thanks!
Follow TheHEMI.com on TWITTER, FACEBOOK and/or MEWE !
Re: Casting 2468339? [Re: TheHemi] #2548705
09/11/18 11:29 AM
09/11/18 11:29 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Looks like a mistake. 9 for 0. 2468330 is correct.
2011 Drag Pak Challenger
Re: Casting 2468339? [Re: TheHemi] #2548802
09/11/18 02:44 PM
09/11/18 02:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In many cases, the points of the digits in the casting number, formed during the casting process, will run together making an undecipherable blob.
Re: Casting 2468339? [Re: TheHemi] #2549456
09/13/18 12:37 AM
09/13/18 12:37 AM
Texas
TheHemi Offline OP
TheHemi  Offline OP
Texas
Interesting. I will see if I can get a photo. Thanks!
Re: Casting 2468339? [Re: TheHemi] #2549572
09/13/18 12:44 PM
09/13/18 12:44 PM
central il.
second 70 Offline
second 70  Offline
central il.
If you can get a picture of the top of the block it will be easy to see if it has the added casting to bolt on the heads.
Mike
Re: Casting 2468339? [Re: second 70] #2558707
10/04/18 01:06 AM
10/04/18 01:06 AM
Texas
TheHemi Offline OP
TheHemi  Offline OP
Texas
OK, I received a couple photos.
2468330-M is the casting
7H18 is another casting
Does the -M and/or 7H18 have any significance?
Re: Casting 2468339? [Re: TheHemi] #2558821
10/04/18 11:30 AM
10/04/18 11:30 AM
Stuttgart, Arkansas
Stuttgart, Arkansas
-M (millennium I guess) is what they put on the "new" blocks (and heads) when they re-released them in the 90's.
Re: Casting 2468339? [Re: TheHemi] #2558850
10/04/18 12:22 PM
10/04/18 12:22 PM
central il.
second 70 Offline
second 70  Offline
central il.
I don't know for sure but I guess that's some kind of date.
Mine is 6K29 All the blocks are M.
Re: Casting 2468339? [Re: second 70] #2559015
10/04/18 07:04 PM
10/04/18 07:04 PM
dogdays Offline
dogdays  Offline
The "-M" was put after the casting number so they would not be mistaken for original Hemi castings. I remember reading that at the time. No mention of it meaning anything.
I'm thinking 6K29 is November 29, 1996.
R.
Re: Casting 2468339? [Re: dogdays] #2560335
10/07/18 01:09 PM
10/07/18 01:09 PM
central il.
second 70 Offline
second 70  Offline
central il.
[quote=dogdays]The "-M" was put after the casting number so they would not be mistaken for original Hemi castings. I remember reading that at the time. No mention of it meaning anything.
Hard to know top pad is stamped HW1194. I'm guessing the HW means Hemi Wedge motor mounts? No idea on the numbers.
