small block 727 dipstick/tube #2547863
09/09/18 11:32 AM
09/09/18 11:32 AM
PA
maxwedge1 Offline OP
PA
orderd a repro tube and stick for a small block 727, the tip of the stick barely sticks out of the tube wich puts full mark up in the tube an inch or more, doesnt seem right ??
Re: small block 727 dipstick/tube [Re: maxwedge1] #2547873
09/09/18 12:00 PM
09/09/18 12:00 PM
I forget how far it is supposed to protrude with it seated. John posted it prior but I did not write it down.
Re: small block 727 dipstick/tube [Re: RapidRobert] #2547880
09/09/18 12:10 PM
09/09/18 12:10 PM
moparx Offline
moparx  Offline
somewhere in my mind, the correct full level is 1/4" or so, above the case opening/pan rail. all the sticks i have, the stick doesn't "stick out" much past the tube end. pun intended, of course. biggrin
beer
Re: small block 727 dipstick/tube [Re: moparx] #2547884
09/09/18 12:19 PM
09/09/18 12:19 PM
PA
PA
ok thanks, i didnt think the correct level would of been that high.
Re: small block 727 dipstick/tube [Re: maxwedge1] #2547918
09/09/18 01:41 PM
09/09/18 01:41 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I agree, the stick only sticks out of the tube a small amount.
Re: small block 727 dipstick/tube [Re: maxwedge1] #2547984
09/09/18 04:08 PM
09/09/18 04:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It actually varies a little due to the curvature of the tube but, generally, the FULL level is a little over 1/4" above the ledge in the case. The tab in this pic bolts to the ledge.
