727 leak rear band apply shaft
#2547611
09/08/18 02:14 PM
09/08/18 02:14 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
So my 1969 A727B is leaking at the o-ring, rear band apply shaft, where it enters the trans case. After removing the tail shaft, pan and valve body, can I sneak the shaft out far enough to change the o-ring without removing it completely ?
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: 727 leak rear band apply shaft
[Re: dvw]
#2547639
09/08/18 04:35 PM
09/08/18 04:35 PM
5wndwcpe
Southeast PA
Push it in. Clean and apply RTV with a putty knife in the pin bore. Works evert time. Doug Doug, just so I'm clear, you're saying not to remove it all but rather push it in as is, clean the area and spackle over the hole with RTV ? -Pete
[Re: 5wndwcpe]
#2547659
09/08/18 06:20 PM
09/08/18 06:20 PM
Posts: 25,802 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Trouble with sealing the end of the shaft is the leaking fluid will usually prevent the RTV from bonding well; best to drain the fluid level to below the shaft, clean the area really well and then apply the RTV. Let it sit at least over night before refilling the fluid.
[Re: John_Kunkel]
#2547987
09/09/18 04:16 PM
09/09/18 04:16 PM
5wndwcpe
Southeast PA
Trouble with sealing the end of the shaft is the leaking fluid will usually prevent the RTV from bonding well; best to drain the fluid level to below the shaft, clean the area really well and then apply the RTV. Let it sit at least over night before refilling the fluid. Yep, that was going to be my plan of attack. Should that fail, any thoughts on partially removing the shaft to replace the o-ring ?
[Re: 5wndwcpe]
#2548090
09/09/18 08:53 PM
09/09/18 08:53 PM
Posts: 2,190 SW MO
closer9
SW MO
You don't need to remove valve body or filter. Just drop the pan, get a long screwdriver, etc, push the shaft out the inch or so and replace the o-ring. I cut the tab off the tail shaft and made a hold down bracket. Seems like I smeared some RTV over the shaft when I was all done.
Daily: '19 Frontier 4WD Belle: '67 Belvedere Convertible, 318/727 in Go ManGo! Other: '64 C10, 283/3 on the tree
