A body and Ralley wheels????? #2546944
09/06/18 10:33 PM
09/06/18 10:33 PM
Western Colorado High Desert
moparmarks Offline OP
I have a 73 K-frame and suspension with 11.75 disc on my 72 Dart. Put on a set of factory 15" Ralleys and the wheels are hitting the upper control arms. WTH. Can't run these wheels on an A body????
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: A body and Ralley wheels????? [Re: moparmarks] #2546951
09/06/18 10:43 PM
09/06/18 10:43 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Never put 15" ralleys on an A-Body before, only 14". Must have different backspacing, 6-1/2 or 7? shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: A body and Ralley wheels????? [Re: moparmarks] #2546955
09/06/18 10:52 PM
09/06/18 10:52 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I’ve run 15x7 cop rims that have the same as stock 15x7 rallyes: 4 1/4 backspacing.
That clearance is the same as a any E or B body with the only exception of the upper control arm. Is your UCA original or repro? Are you rallyes OE 15x7 or repro?
Also notice this is with the suspension all dropped down. Do you have the UCA bump stops installed? Even with them it’s close. When you put it and ride height, that clearance gets bigger.
If you haven’t aligned it yet, you could have too much negative camber (top tilted inwards). And would reduce that clearance.
I’ve run 15x8 rallyes with 4 1/2 backspacing. That’s a 1/4” closer. I had a tire blowout and it knocked all the inside wheel weights off.
Re: A body and Ralley wheels????? [Re: moparmarks] #2546972
09/06/18 11:25 PM
09/06/18 11:25 PM
Factory original 15x7 4.25 BS. I think that is the BS, need to check.
Original factory UCA's
Bump stops and everything is install. Have not done the alignment yet.
When raised in the air can turn the wheels but when I drop it on the ground then they hit.
I do have the T/bar up a bit too much.
So Steve you have ran this setup?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: A body and Ralley wheels????? [Re: moparmarks] #2546998
09/07/18 12:18 AM
09/07/18 12:18 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
With cop rims, yes. They have the same 15x7 backspacing.
And I’ve run it with 15x8 rallyes I had made with 4 1/2 backspacing. Those had aftermarket outer hoops. But I was never close with the 15x7’s.
Re: A body and Ralley wheels????? [Re: moparmarks] #2547006
09/07/18 12:44 AM
09/07/18 12:44 AM
Colorado
spk2go Offline
spk2go  Offline
Colorado
Is the ball joint all the way seated into the spindle?
Re: A body and Ralley wheels????? [Re: spk2go] #2547012
09/07/18 12:52 AM
09/07/18 12:52 AM
Yep. Rims are rubbing on both sides.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: A body and Ralley wheels????? [Re: spk2go] #2547099
09/07/18 10:58 AM
09/07/18 10:58 AM
New York
rarefish Online content
rarefish  Online Content
New York
Just a thought, but is that the 72 spindle with a 73 upper ball joint attached?
If so, then we have two different sizes working against each other.
Re: A body and Ralley wheels????? [Re: moparmarks] #2547112
09/07/18 11:21 AM
09/07/18 11:21 AM
No it's not a 72 and down spindle.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: A body and Ralley wheels????? [Re: moparmarks] #2547115
09/07/18 11:26 AM
09/07/18 11:26 AM
Ok here is better shot. I added some wheel spacers so I can roll the car. I think that I may have found the problem. The UCA is actually points upwards toward the rim. I'm think I may have grabbed a set up 73-up B body spindles out of my stock instead of the 73-up A/E ones. 73-up B spindles are taller than the rest.
What do you guys think?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: A body and Ralley wheels????? [Re: moparmarks] #2547139
09/07/18 12:12 PM
09/07/18 12:12 PM
Well color me silly. That is what I've done. These spindles are 3/4" taller than the ones on the B and E bodies I have in the shop.
Just love moving backwards. runaway
Thanks for your input guys.
See ya at the Fling Steve.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: A body and Ralley wheels????? [Re: moparmarks] #2547158
09/07/18 12:36 PM
09/07/18 12:36 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I know the curse of having too many parts in stock as well... realcrazy
A-Body's RULE!
