A body and Ralley wheels?????
#2546944
09/06/18 10:33 PM
09/06/18 10:33 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I have a 73 K-frame and suspension with 11.75 disc on my 72 Dart. Put on a set of factory 15" Ralleys and the wheels are hitting the upper control arms. WTH. Can't run these wheels on an A body????
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: A body and Ralley wheels?????
[Re: moparmarks]
#2546951
09/06/18 10:43 PM
09/06/18 10:43 PM
Posts: 43,507 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Never put 15" ralleys on an A-Body before, only 14". Must have different backspacing, 6-1/2 or 7?
JB Rhinehart, Realist
A-Body's RULE!
[Re: moparmarks]
#2546972
09/06/18 11:25 PM
09/06/18 11:25 PM
moparmarks
Factory original 15x7 4.25 BS. I think that is the BS, need to check. Original factory UCA's Bump stops and everything is install. Have not done the alignment yet. When raised in the air can turn the wheels but when I drop it on the ground then they hit. I do have the T/bar up a bit too much. So Steve you have ran this setup?
[Re: moparmarks]
#2546998
09/07/18 12:18 AM
09/07/18 12:18 AM
Posts: 27,451 So Cal
autoxcuda
So Cal
Factory original 15x7 4.25 BS. I think that is the BS, need to check. Original factory UCA's Bump stops and everything is install. Have not done the alignment yet. When raised in the air can turn the wheels but when I drop it on the ground then they hit. I do have the T/bar up a bit too much. So Steve you have ran this setup? With cop rims, yes. They have the same 15x7 backspacing. And I’ve run it with 15x8 rallyes I had made with 4 1/2 backspacing. Those had aftermarket outer hoops. But I was never close with the 15x7’s.
[Re: spk2go]
#2547099
09/07/18 10:58 AM
09/07/18 10:58 AM
Posts: 2,252 New York
rarefish
New York
Is the ball joint all the way seated into the spindle? Just a thought, but is that the 72 spindle with a 73 upper ball joint attached? If so, then we have two different sizes working against each other.
[Re: moparmarks]
#2547115
09/07/18 11:26 AM
09/07/18 11:26 AM
moparmarks
Ok here is better shot. I added some wheel spacers so I can roll the car. I think that I may have found the problem. The UCA is actually points upwards toward the rim. I'm think I may have grabbed a set up 73-up B body spindles out of my stock instead of the 73-up A/E ones. 73-up B spindles are taller than the rest. What do you guys think?
[Re: moparmarks]
#2547139
09/07/18 12:12 PM
09/07/18 12:12 PM
moparmarks
Well color me silly. That is what I've done. These spindles are 3/4" taller than the ones on the B and E bodies I have in the shop. Just love moving backwards. Thanks for your input guys. See ya at the Fling Steve.
