Re: Trick Flow 270 OOTB quality?????
[Re: mercman1]
#2545376
09/03/18 10:23 PM
09/03/18 10:23 PM
fast68plymouth
So. Burlington, Vt.
I have a set in the shop now........ the guide clearance is def tighter than what I’d prefer to see...... on this set they’re right at .0006”.
[Re: Twostick]
#2545447
09/04/18 12:06 AM
09/04/18 12:06 AM
Posts: 20,200 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Always assume parts are junk OOTB until proven otherwise. Just because nobody else has had any problems doesn't mean you won't.
Kevin Remember every week has a monday and a Friday and possibly a thirsty Thursday
