Removing tachometer from 1968 Super Bee Ralley cluster #2544600
09/02/18 01:13 PM
09/02/18 01:13 PM
Ohio
lockjaw-express Offline OP
Ohio
Is it possible to remove the tachometer or speedometer without pulling the whole gauge cluster?
Also, what would be the process for just removing the front plate?
Thank you for your help!
Mark
Re: Removing tachometer from 1968 Super Bee Ralley cluster [Re: lockjaw-express] #2544628
09/02/18 01:43 PM
09/02/18 01:43 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
No, the complete cluster has to come out for everything you are asking.
Re: Removing tachometer from 1968 Super Bee Ralley cluster [Re: lockjaw-express] #2544709
09/02/18 04:04 PM
09/02/18 04:04 PM
Ohio
Ohio
That is what I was afraid of...
Thank you!
Re: Removing tachometer from 1968 Super Bee Ralley cluster [Re: lockjaw-express] #2544717
09/02/18 04:39 PM
09/02/18 04:39 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Tach comes out the backside and best I remember can be removed without pulling entire cluster assy. Just not easily for old farts.
Speedo comes out the front and can only be removed via pulling and disassemble cluster assy
Re: Removing tachometer from 1968 Super Bee Ralley cluster [Re: gtx6970] #2544763
09/02/18 06:43 PM
09/02/18 06:43 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
iagree recently had the tach in-n-out on a Superbird with the cluster still installed (if OPTIONED, A/C ducts may make this impossible)
Re: Removing tachometer from 1968 Super Bee Ralley cluster [Re: lockjaw-express] #2544782
09/02/18 08:20 PM
09/02/18 08:20 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Mark
It's a LOT easier just to pull the whole cluster. Unless you like working on your back and not being able to see the screws holding it in, and working them out with a screw driver or a nut driver. It's one thing loosening screws and having them fall on your face; it's another trying to put them back in and holding the gauge in place at the same time. If you're young, and a contortionist, go for it! My human pretzel days are over..
Re: Removing tachometer from 1968 Super Bee Ralley cluster [Re: lockjaw-express] #2544818
09/02/18 09:44 PM
09/02/18 09:44 PM
Ohio
Ohio
Thank you all for the advise!
I do not have a heat box or ac box, so that might make it easier...I guess I can always pull the drivers bucket seat to make it easier.
Mark
