lash cap fitment Q
#2542481
08/28/18 01:57 PM
08/28/18 01:57 PM
RapidRobert
The "depth" inside these is greater than the distance from the locks up to the tip of the valve (the cap will be pushing down on the locks as opposed to touching/contacting the stem tip). Problem? (or not). (Trying to mix & match some of my "extras". thank you for your time.
Re: lash cap fitment Q
[Re: HardcoreB]
#2542496
08/28/18 02:09 PM
08/28/18 02:09 PM
RapidRobert
Will do, thank you! (just too many extras laying around which ain't unique with us).
[Re: RapidRobert]
#2542676
08/28/18 07:25 PM
08/28/18 07:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
With those wire locks it will try to open up the wire and drop the valve.. the caps should be close but not touching the locks
[Re: MR_P_BODY]
#2542727
08/28/18 08:39 PM
08/28/18 08:39 PM
RapidRobert
Actually that is a regular set of locks (I see the "wire" appearance I think you mean). The tall cap does look hokey in the pic but I am trying to downsize & like alot of us, I just have too much unfinished projects/unused new/used parts & clutter.
[Re: RapidRobert]
#2542785
08/28/18 10:45 PM
08/28/18 10:45 PM
MR_P_BODY
I see.. all the locks I use have a square edge on the top.. no big deal then
[Re: RapidRobert]
#2542792
08/28/18 10:59 PM
08/28/18 10:59 PM
Posts: 4,206 New York
polyspheric
New York
If the cap ID is not a snug radial (annular) fit on the stem, it will rock slightly - add some clearance to the lock.
Boffin Emeritus
[Re: polyspheric]
#2542822
08/29/18 12:34 AM
08/29/18 12:34 AM
RapidRobert
I've been sitting on these caps for at least 10 yrs & I just saw that they fit the 8MM valves in my EQ heads cuz it fit the OE 8mm used magnum valve in the pic (snug). I am haveing alot of problems with setting rocker geometry on em (high lift cam/EQ heads) & I thought that the lash caps might be an answer if needed (not likely tho).
[Re: hemi-itis]
#2542877
08/29/18 02:46 AM
08/29/18 02:46 AM
RapidRobert
Lash caps should NEVER hit the keepers!! Alright, back on the shelf they will go
