lash cap fitment Q #2542481
08/28/18 01:57 PM
08/28/18 01:57 PM
RapidRobert Offline OP
The "depth" inside these is greater than the distance from the locks up to the tip of the valve (the cap will be pushing down on the locks as opposed to touching/contacting the stem tip). Problem? (or not). (Trying to mix & match some of my "extras". thank you for your time.
Re: lash cap fitment Q [Re: RapidRobert] #2542487
08/28/18 02:01 PM
08/28/18 02:01 PM
P
Porter67 Offline
Porter67  Offline
P
Use the locks made for lash cap use, look on summit at the comp cams products.
Re: lash cap fitment Q [Re: RapidRobert] #2542488
08/28/18 02:04 PM
08/28/18 02:04 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
YES that is a problem...no way you'll get away running that way. Many varieties in locks and caps available...don't cheap out on valvetrain..it'll bite you.
Re: lash cap fitment Q [Re: HardcoreB] #2542496
08/28/18 02:09 PM
08/28/18 02:09 PM
Will do, thank you! (just too many extras laying around which ain't unique with us).
Re: lash cap fitment Q [Re: HardcoreB] #2542518
08/28/18 02:47 PM
08/28/18 02:47 PM
iagree
Do NOT use any lash cap that does not sit on the valve stem without touching the retainers tsk
Re: lash cap fitment Q [Re: Cab_Burge] #2542657
08/28/18 06:47 PM
08/28/18 06:47 PM
Thanks Cab
Re: lash cap fitment Q [Re: RapidRobert] #2542673
08/28/18 07:23 PM
08/28/18 07:23 PM
new zealand
matt426 Offline
matt426  Offline
new zealand
Put them in the lathe or drill press ,with the chuck turning grind them with a small disc grinder to give .015-.020 clearance.Gives a good custom fit.
Re: lash cap fitment Q [Re: RapidRobert] #2542676
08/28/18 07:25 PM
08/28/18 07:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With those wire locks it will try to open up
the wire and drop the valve.. the caps should
be close but not touching the locks
wave
Re: lash cap fitment Q [Re: MR_P_BODY] #2542727
08/28/18 08:39 PM
08/28/18 08:39 PM
Actually that is a regular set of locks (I see the "wire" appearance I think you mean). The tall cap does look hokey in the pic but I am trying to downsize & like alot of us, I just have too much unfinished projects/unused new/used parts & clutter.
Re: lash cap fitment Q [Re: RapidRobert] #2542785
08/28/18 10:45 PM
08/28/18 10:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I see.. all the locks I use have a square edge
on the top.. no big deal then
wave
Re: lash cap fitment Q [Re: RapidRobert] #2542792
08/28/18 10:59 PM
08/28/18 10:59 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If the cap ID is not a snug radial (annular) fit on the stem, it will rock slightly - add some clearance to the lock.
Boffin Emeritus
Re: lash cap fitment Q [Re: polyspheric] #2542822
08/29/18 12:34 AM
08/29/18 12:34 AM
I've been sitting on these caps for at least 10 yrs & I just saw that they fit the 8MM valves in my EQ heads cuz it fit the OE 8mm used magnum valve in the pic (snug). I am haveing alot of problems with setting rocker geometry on em (high lift cam/EQ heads) & I thought that the lash caps might be an answer if needed (not likely tho).
Re: lash cap fitment Q [Re: RapidRobert] #2542865
08/29/18 02:02 AM
08/29/18 02:02 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
There are "short" caps as well.
https://www.jegs.com/p/COMP-Cams/Comp-Cams-Valve-Lash-Caps/753205/10002/-1
Lash caps should NEVER hit the keepers!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: lash cap fitment Q [Re: hemi-itis] #2542877
08/29/18 02:46 AM
08/29/18 02:46 AM
Alright, back on the shelf they will go
