Slick size needed #2541933
08/27/18 11:18 AM
08/27/18 11:18 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Hi folks,
Have 440 6 pack in our charger, 727 RMVB w/ 2800 converter (383 Hi-po), 4:10 gear.
Probably close 4000#, dyno'd at 465HP, Peaked at 6200 RPM
Would like to trap at 6200, shift at around 5700.
Our local track is not prepped, to say the least.
Have standard wheel wells and 15X8" rims to use.
Am going to quiz Hoosier on their recommendation for compound,
but need a size that will maximize the car's abilities.
Don't plan on a lot of track time, just to know what it is capable of.
Standard rear suspension with a pinion snubber (I know, I know)
Thanks, Joe
Re: Slick size needed [Re: jlatessa] #2541938
08/27/18 11:20 AM
08/27/18 11:20 AM
an8sec70cuda Offline
28x10.5
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Slick size needed [Re: an8sec70cuda] #2541968
08/27/18 12:13 PM
08/27/18 12:13 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Hoosier's recommendation was their #18155, C07 compound at 12-14 PSI.
28-10.3"
Sound right?
This is a bias ply slick and I thought the consensus was radial??
Joe
Re: Slick size needed [Re: jlatessa] #2541971
08/27/18 12:16 PM
08/27/18 12:16 PM
The radial will be faster, but the bias ply more consistent depending on track conditions.
If you want a street legal drag radial, get a 275-60.
I've always run M/T tires so I'm not real familiar w/ Hoosiers numbers.
CHIP
Re: Slick size needed [Re: jlatessa] #2541981
08/27/18 12:34 PM
08/27/18 12:34 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
I think we'll stick with a drag tire as our 275-60s hook plenty on the street.
The track... holy crap, could NOT get them to hook at all at the line,
the shift light looked like a strobe!!
Joe
PS they didn't recommend tubes or rim screws at that PSI, just some
HI Tack on the beads.
Joe
Re: Slick size needed [Re: jlatessa] #2542038
08/27/18 03:06 PM
08/27/18 03:06 PM
Cab_Burge Online work
Cab_Burge  Online Work
What year charger and how much room do you have with the current tires and wheels? I would run the biggest bias ply slick I could fit on your car up twocents Maybe 10.5x29 or larger work scope
Re: Slick size needed [Re: jlatessa] #2542060
08/27/18 03:46 PM
08/27/18 03:46 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Sorry Cab, 70 Charger RT.
The 275-60 BFGs have plenty of room,no rubbing anywhere.
I'll take some measurements as far as sitting clearance, Thanks,
Joe
Re: Slick size needed [Re: jlatessa] #2542103
08/27/18 05:50 PM
08/27/18 05:50 PM
my own world
theraif Offline
theraif  Offline
my own world
sounds like one of tracks south of rt76 grin
Re: Slick size needed [Re: jlatessa] #2542558
08/28/18 03:34 PM
08/28/18 03:34 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
I don't want to burn any bridges, but it's a N. East Ohio track.
As to my current clearances, with a 15x7" wheel, standard backspace and 275-60 BFGs, I have 2" to the leaf spring, 1" to the inner fender flange if the tire would ever get that high.
So I'll check the specs on Hoosier's tires in the ranges that have been suggested, i.e. 28-10.3 and 29-10.3
Thanks all, Joe
